Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
gas-liquid vertical separator
Old   March 23, 2021, 11:11
Default gas-liquid vertical separator
Zahra dastyar
Zahra Dastyar is on a distinguished road
Hi everybody, it's 4 months I'm working hardly on my thesis without any significant results,
my problem is a vertical separator (that you can see in the picture), 2phase flow inters the separator via inlet holes, the gas should be separate from liquid due to gravitational and centrifugal forces, then the free gas exits the separator from top holes and liquid exits from the inner tube, which is not happen
to simulate this I tried all the options in fluent include: Mixture model both dispersed and sharp/dispersed, Eulerian and also interfacial area concentration option, different diameters for gas phase, different surface tension models
and k-e RNG with different wall functions
I used fluent meshing and the poly hex mesh is generated
Inlet condition is mass flow inlet and outlets are pressure outlet
the problem is that the magnitude of gas/liquid does not change in any method and no gas separates
I have to solve this using steady model because the transient longs for weeks.
I would appreciate your help
Zahra Dastyar is offline   Reply With Quote
Old   April 20, 2021, 04:02
België
InsPyro is on a distinguished road
Hello Zahra,
If all of these methods fail, my guess would be something is wrong with the design or with the geometry set-up. If the design isn't proven, then your cfd result may be correct. If the design works in practice, you could check the basics such as gravity orientation, internal walls being actual boundaries etc.
InsPyro is offline   Reply With Quote
Domain Reference Pressure and mass flow inlet boundary AdidaKK CFX 75 August 20, 2018 05:37
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Liquid/ Gas flow with VOF rt FLUENT 0 May 11, 2006 02:17
gas liquid flow Yuqing Feng CFX 0 May 4, 2004 21:26
Gas adsorption into liquid..HOW?? Ivan FLUENT 0 July 3, 2003 01:38
