Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
No heat transfer between multiple parts
Old   April 26, 2021, 06:06
Post No heat transfer between multiple parts
Raj
Rajkool is on a distinguished road
Hello all,
I have a body that needs to be heated internally. The heat source is inside the body. All the geometries are considered fluids. So, fluid geometries are divided into multiple parts. The temperature is given on the face of the center part of the body (On the face of the small body). As you can see in the temperature contours, the heat is distributed only on one part. But I need the distribution along with the flow i.e, on the next body. Please suggest to me some solution to this problem. (All parts have a shared topology and all solids are considered as a single part. I have also given manual contacts but the results are the same. The mesh is also perfectly structured.)
Thank you
Rajkool is offline   Reply With Quote
Modelling the wall heat transfer magicbretzel CONVERGE 5 March 3, 2021 04:38
Coupled Heat and Mass Transfer Mecroob OpenFOAM Running, Solving & CFD 1 July 12, 2020 19:24
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
Question about heat transfer simulation Anna Tian Main CFD Forum 0 January 25, 2013 18:53
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
