June 12, 2021, 04:16 |
Setting enclosure to certain limits
Raj
Rep Power: 6 |
Hello guys,
I am working on a 3D cylindrical geometry as a Multiphase VOF model. I would like to specify air as the enclosure. In a way, the enclosure at the Inlet and Outlet are avoided. I tried to do it by the User-defined option in Enclosure but it did not work. Please help if you can? Thanks in advance Raj |
enclosure, enclosure box, enclosure.air.default |
using chemkin | JMDag2004 | OpenFOAM Pre-Processing | 2 | March 8, 2016 22:38 |
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 09:53 |
Cells with t below lower limit | Purushothama | Siemens | 2 | May 31, 2010 21:58 |
setting limits | Mac | Siemens | 5 | October 11, 2007 06:13 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
