June 29, 2022, 02:26 |
Latent Heat Cannot be Less than zero
Hellboy
Rep Power: 8 |
Hi all, I'm practicing multiphase analysis in fluent,
my problem involves air, R134a liquid & R134a vapour I have assign the properties and while going through initialization i have noticed this error. Compute Node ID: 3 From-phase Domain ID: 1 To-phase Domain ID: 2 Cell Number: 0 Latent Heat: -294579 ERROR: Latent heat cannot be less than zero! could you please help me to understand and resolve this error |
November 7, 2022, 03:20 |
Sree Kumaran T
Rep Power: 3 |
have u found out how to solve the error
November 12, 2022, 10:25 |
Hellboy
Rep Power: 8 |
yes, it is solved
November 12, 2022, 10:44 |
Sree Kumaran T
Rep Power: 3 |
Can u share how did u solve it please
November 12, 2022, 10:54 |
Hellboy
Rep Power: 8 |
sure, in ansys it is suggested to consider latent heat for refrigerant in liquid material as zero
in ansys fluent, latent heat is calculated from standard state enthalpy of phase participating in mass exchange only enthalpy difference matters hvl(enthalpy total or vapour & liquid at ref temperature)= hv(vapour enthalpy)-hl(liquid enthalpy) at reference temperatures so it is better to consider liquid enthalpy as zero |
November 12, 2022, 10:55 |
Hellboy
Rep Power: 8 |
it is better to use
Tref= Tsat hv, Tsat= hvl,Tsat |
November 12, 2022, 11:08 |
Sree Kumaran T
Rep Power: 3 |
So in a evaporation condensation cycle should i put sse of water zero and air as it is
March 27, 2023, 10:34 |
mohammed ibrahim
#multiphasefluent #vof |
heat not balanced in the chtMultiRegionSimpleFoam solver | carye | OpenFOAM | 19 | September 26, 2019 04:25 |
what is latent heat of ethanol at 30 degree saturation temperature? | 1757003@kiit.ac.in | FLUENT | 0 | May 15, 2019 05:34 |
Heat Release vs. Apparent Heat Release // Comparison with GT Power | MFGT | CONVERGE | 10 | August 17, 2016 02:38 |
Compression stoke is giving higher pressure than calculated | nickjuana | CFX | 62 | May 19, 2015 13:32 |
Enforce bounds error with heat loss boundary condition at solid walls | Chander | CFX | 2 | May 1, 2012 20:11 |
