Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Relations between time step, velocity and volume fraction in DES-Mixture model sims
Old   July 8, 2022, 11:47
Default Relations between time step, velocity and volume fraction in DES-Mixture model sims
Hans
14.mala is on a distinguished road
I am currently running a simulation of a dilute gas-liquid mixture inside a pipe with some internals. I am using the DES turbulence model (+RNG k-\varepsilon model) together with the mixture multiphase model (obtaining the interphase slip velocity through an algebraic equation, rather than solving transport equations for each phase).
To speed up the flow development in the early stages of the simulation, I adopted larger time steps and everything worked as expected. Just when I reduced the time step to increase accuracy I noticed that lowering the time step (I'm using implicit second order discretization) the dispersed phase velocity increases to values well above the expected magnitude. With an inlet velocity of around 1m/s I get characteristic velocities close to 7 m/s in the pipe. This also affects the gas-phase volume fraction that decreases (I guess to get a gas-flux matching the one imposed at the boundary conditions).
I've never noticed this behavior neither with single-phase DES nor with RANS Eulerian two-fluid model. Has someone experienced something like this before? Do you have any suggestions?
Thanks,
H.
P.s.
In single phase the DES simulation with the current mesh gives mean and fluctuating velocities that almost perfectly match the experimental observations. RANS TFM simulations with the same mesh gave realistic results, which were validated with experiments.
H.
14.mala is offline   Reply With Quote
des, fluent, mixture model, multiphase, time step
[solidMechanics] Support thread for "Solid Mechanics Solvers added to OpenFOAM Extend" bigphil OpenFOAM CC Toolkits for Fluid-Structure Interaction 686 December 22, 2022 09:10
attachmentPt for floating body at each time step for overInterDyMFoam solver mahsankhan OpenFOAM Running, Solving & CFD 0 January 24, 2022 11:13
objects oscillate at high speed causing collapse in Dynamic mesh and overset mesh ca insane OpenFOAM Running, Solving & CFD 0 May 17, 2020 22:35
Multiple floating objects CKH OpenFOAM Running, Solving & CFD 14 February 20, 2019 09:08
Stuck in a Rut- interDyMFoam! xoitx OpenFOAM Running, Solving & CFD 14 March 25, 2016 07:09
