July 20, 2022, 22:02 |
Convergence problem fludized bed
Hello. I'm trying to simulate a 3D fludized bed using a eulerian-eulerian approach. When I restrict the inlet area, fluent diverges and show me the message: floating point exception. I'm using gidaspow for granular viscosity and drag coefficient.
inlet velocity: 0.12 m/s diameter of particles: 0.000163m density: 2820 kg/m3 base radius: 0.073m inlet radius: 0.01m step size: 0.001 element size: 0.005 If my inlet area is the base area (0.073m of radius) the is no problem, but when I put the named section with 0.01m of radius, the problem diverge after 20 interections. Thank you very much in advance |
July 21, 2022, 04:25 |
#2 | |
Void_CFD-user
Rep Power: 4 |
A general advice, in the tui you can type /report/mphase-summary and select 1 for verbosity. It will give you all sorts of recommendation and suumary |
August 7, 2022, 19:03 |
#3 | |
Convergence problem and the Mach problem in supersonic model | ranxiaoran | FLUENT | 2 | July 28, 2021 12:27 |
SU2-7.0.1 on ubuntu 18.04 | hyunko | SU2 Installation | 7 | March 16, 2020 04:37 |
a problem with convergence in buoyantSimpleFoam | skuznet | OpenFOAM Running, Solving & CFD | 6 | November 15, 2017 12:12 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 22:03 |
CONVERGENCE PROBLEM - oil boiler | MM | FLUENT | 1 | February 15, 2007 05:24 |
