Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Mass transfer in Multi phase problem
Old   July 22, 2023, 13:41
Default Mass transfer in Multi phase problem
Chhotelal
Chhotelal1234 is on a distinguished road
In the Muti-phase problem, heat and mass transfer between phase interaction, Gunn equation is available for heat transfer phenomenon which is the function of Nussult number, that gives heat transfer coefficient. In the mass transfer case is it applicable Other Nussult number based on Sherwood number. Because there is not giving Gunn equation. How can I calculate mass transfer coefficient, and how is it incorporates in governing equation.
Chhotelal1234 is offline   Reply With Quote
Discrete Phase Model, outlet mass flow rate does not fit edu_aero FLUENT 29 February 3, 2020 08:38
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 06:20
[swak4Foam] mass conservation of solid phase violated when using groovyBC with twoPhaseEulerFoam xpqiu OpenFOAM Community Contributions 8 June 17, 2015 02:08
About phase change heat and mass transfer Michael FLUENT 2 February 13, 2011 01:49
liquid phase reactions and mass transfer Swarup FLUENT 0 January 17, 2005 00:47
