Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Caculating porous zone parameters for open channel flow?
Old   June 30, 2023, 09:03
Default Caculating porous zone parameters for open channel flow?
mmengineer is on a distinguished road
Hello Everyone,
i´m trying to simulate a porous zone in an Open Channel Flow and i would like to calculate the porous resistance parameters based on experimental data. Such as shown for example in the ANSYS Fluent help.
I have experimental data with the fluid height upstream an downstream the porous medium, which is located over the complete width of the test flume. I have the discharge value and averaged velocitys upstream and downstream, based on the fluid height and discharge.
I think there is a way to calculate the parameters with the experimental data, but i´m not sure how.
Within the experiments i also measured the dragging force on the porous zone, which could maybe translated into a pressure drop to derive C1 and C2, but i don´t know how to do it because of the different fluid heights upstream and downstream the porous zone (and the different fluid heights depending on the discharge).
I only found instructions how to calculate the parameters out of experimental data for flow in pipes or similar closed channels, but not for open channels like in my case. So if someone could help me i would be quite happy
Regards
mmengineer is offline   Reply With Quote
porous media
LES Setup of a cyclic channel flow for compressible solver Phil910 OpenFOAM Running, Solving & CFD 2 October 29, 2022 04:24
Flow through a simple porous rectangular channel kinni CFD Freelancers 3 October 21, 2016 10:05
Porous zone in a flow simulations roger333 OpenFOAM Pre-Processing 2 October 20, 2016 07:47
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 09:28
Need help!:Particle flow through porous zone lig FLUENT 0 April 26, 2010 00:47
