Maximum velocity error when applying mass flow rate outlet boundary conditions |
May 14, 2024, 10:31 |
Abaid
Rep Power: 2 |
Hello Everyone,
I'm researching coronary artery disease and simulating parabolic velocity profiles in ANSYS Fluent. My goal is to distribute the flow into three outlets, with 96% going to one outlet and the remaining 4% divided between the other two. Initially, I set the mass flow rate outlet boundary conditions, but I noticed that the maximum velocity obtained was 0.04, which is higher than the intended 0.008. However, when I applied a zero pressure gradient at outlet boundary conditions, then the maximum velocity was consistent with the expected value of 0.008. What might be causing this discrepancy? Any assistance would be greatly appreciated. The link of the image is http://vascularmodel.org/dataset.html#0 Thank you. |
Ncrit for a glider Xfoil. How to use it. GPT4 answer | AlanMattanó | Main CFD Forum | 0 | April 10, 2023 12:16 |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Question about adaptive timestepping | Guille1811 | CFX | 25 | November 12, 2017 17:38 |
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field | xiexing | CFX | 3 | March 29, 2017 10:00 |
Pressure Outlet Targeted Mass Flow Rate | LuckyTran | FLUENT | 1 | November 23, 2016 10:40 |
