Reversed flow on 9 faces of pressure-outlet 11 |
Shrestha
Rep Power: 0 ![]() |
Hi! I set up a VOF simulation with two phases (water and vapor), with water at the beginning filling the domain with water flow inlet at 0.004 m/s in a 2D rectangular mesh. Pressure outlet and heat flux input at bottom side. At outlet gauge pressure = 79997.66972 [Pa], operating pressure= 400000 [Pa], so that I have an absolute pressure of 479997.6697 [Pa].
However, even after around 335k iterations, and the wall temperature having passed beyond the saturation temperature of water (423 K at 5 bar), evaporation is not taking place. Heat flux at lower wall is around 90 kW/m2, other wall is adiabatic. I used "to phase frequency" =10 s^-1. There seems to start some nucleation at the bottom surface, but it’s taking way long to form bubbles, or is this normal? Also, I keep getting this: Reversed flow on 9 faces of pressure-outlet 11. 344621 1.2086e-04 5.2476e-05 4.2446e-05 1.2394e-08 0:00:01 149 !344621 solution is converged step flow-time report-def-1 328052 7.7101e-01 4.1939e+02 Flow time = 0.7710071859378018s, time step = 328052 299948 more time steps Updating solution at time level N… Global Courant Number [Explicit VOF Criteria] : 0.000153432 done. It does not iterate and says converged, but the residuals look fine. 24-05-2024-1716577792-mceclip0.png 24-05-2024-1716577826-mceclip1.png 24-05-2024-1716577905-mceclip2.jpg |
Reversed flow using pressure inlet and outlet? | here_for_help | FLUENT | 0 | September 28, 2018 15:20 |
GenerateVolumeMesh Error - Surface Wrapper Self Interacting (?) | AndreP | STAR-CCM+ | 10 | August 2, 2018 07:48 |
reversed flow in xxxx faces on pressure outlet | medaouarwalid | FLUENT | 7 | June 5, 2017 19:46 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
