Heat transfer UDF
Old   April 27, 2012, 04:38
Default Heat transfer UDF
felicemastronzo's Avatar
Felice
felicemastronzo is on a distinguished road
Hi all,
I have a gearbox filled with oil. The motion of the internal gears heat the oil. I want to calculate the temperature distribution in the oil bath. Which BC should I set on the external boundaries (the case of the gearbox)? I do not know the temperature of the walls but only the temperature of the ambient (air). I know that the heat transfer coeff. h is depending on the delta T between the walls and the external air. If I want define that coefficient according to a known law, what should I do? Can someone help me writing an UDF?
Regards
F
felicemastronzo is offline   Reply With Quote
Two-sided Wall Heat Transfer BC - No Separate Solid Mesh and No Heat Transfer Coeff swahono OpenFOAM Running, Solving & CFD 10 October 15, 2018 05:43
Heat transfer (conduction) between two pipes shields FLUENT 14 February 3, 2016 07:45
UDF for heat transfer ranjit FLUENT 13 January 18, 2007 10:36
UDF for Heat transfer coefficient Dong Wenchao FLUENT 2 August 23, 2006 06:35
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
