July 1, 2012, 11:27 |
UDF for linear elasticity of arterial wal
Nina Philipova
Rep Power: 13 |
I have to program UDF for linear elastic wall and parabolic velocity profile at the inlet.
I found this script: #include "udf.h" /*Define Wall Deformation*/ DEFINE_GRID_MOTION( elastic_wall, domain, dynamic_thread, time, dtime) { /*Model Constants*/ /*Elasticity Parameters*/ real E = 400000; /*Young's Modulus (Pa)*/ real vp = .499; /*Poisson's Ratio*/ real h = .0055; /*Wall Thinkness (m)*/ /*Reference Values*/ real Pref = 0; /*Variable Declarations*/ /*Fluent Data Access*/ Thread *tf = DT_THREAD(dynamic_thread); face_t f; Node *v; int n; /*Model Variables*/ real P; /*Wall Pressure*/ real r; /*Radius at wall*/ real NV_VEC(dr); /*Wall Increment*/ real Dw; /*Wall Distensibility*/ /*Set deforming flag on adjacent cell zone */ SET_DEFORMING_THREAD_FLAG(THREAD_T0(tf)); /*??Need to look up exacty what this is doing??*/ /*Loop Over Faces*/ begin_f_loop( f, tf ) { /*Compute Pressure on the face*/ P = -F_P( f, tf ); /*??Minus sign to account for face orientation??*/ Message ("Face Pressure = %f\n", P); /*Loop Over Nodes*/ f_node_loop(f,tf,n) { /*Assign Node Value*/ v = F_NODE(f,tf,n); /*Check if node needs to be updated*/ if (NODE_POS_NEED_UPDATE (v)) { /* Indicate that node position has been updated*/ NODE_POS_UPDATED(v); /*Compute Wall Distensibility*/ r = NODE_Y(v); /*??Does NODE_Y(v) access radial positiion in axisymmetric??*/ Dw = r*(1-vp*vp) / (E*h); /*Increment Wall*/ NV_D( dr, =, 0, r*Dw*( P - Pref ),0 ); NV_V( NODE_COORD(v), +=, dr); /*Debugging*/ Message ("Radius: %f, Deflection: %f\n", r, dr[1] ); }/*end if statement*/ }/*end node loop*/ }/*end face loop*/ end_f_loop( f, tf ) }/*end DEFINE_GRID_MOTION*/ I think that parabolic velocity equation has to estimate the change in radius. I will be grateful to anyone, who can gives any assistance! Wish success to everyone! e-mail: philipova@imbm.bas.bg Last edited by n.phililipova; July 1, 2012 at 11:29. Reason: forget to post e-mail |
July 1, 2012, 11:35 |
Nina Philipova
Rep Power: 13 |
Please I need help as soon as possible
udf and programming |
Source Term UDF VS Porous Media Model | pchoopanya | Fluent UDF and Scheme Programming | 1 | August 28, 2013 06:12 |
UDF parallel error: chip-exec: function not found????? | shankara.2 | Fluent UDF and Scheme Programming | 1 | January 16, 2012 22:14 |
How to add a UDF to a compiled UDF library | kim | FLUENT | 3 | October 26, 2011 21:38 |
UDF...UDF...UDF...UDF | Luc SEMINEL | FLUENT | 0 | November 25, 2002 04:03 |
UDF, UDF, UDF, UDF | Luc SEMINEL | Main CFD Forum | 0 | November 25, 2002 04:01 |
