compile a udf or interpret it?
Old   July 14, 2012, 02:12
Default compile a udf or interpret it?
navid
ndabir is on a distinguished road
I am simulating bubble collapse near wall. when I assume compressible air inside the bubble and incompressible water, my simulation goes well and I get good results. But when I INTERPRET a udf for compressibility of water, I get divergence problems (like unrealistic low pressures).
Do you think interpreting the udf makes this problem? if I compile the udf, would it be solved?
What is the basic difference between interpreting and compiling a udf?
ndabir is offline   Reply With Quote
Old   July 14, 2012, 02:49
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
If there are no warning messages while solving the case with the interpreted UDF, then there should not be any difference when you compile the UDF instead.
In general, interpreted UDFs are the "quick and dirty" solution if the UDF doesn't contain complicated calculations.
There are some restrictions to interpreted UDFs concerning both the C-programming and the data read from the solver. Refer to the UDF manual for details.
A compiled UDF does not have these restrictions and runs much faster.
In your case, it is far more likely that the content of the UDF itself causes the instability of the solving process.
flotus1 is offline   Reply With Quote
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 40 March 18, 2018 06:05
UDF interpret in Fluent wanghaojie Fluent UDF and Scheme Programming 1 February 3, 2012 14:51
udf compile in parallel system tahereh FLUENT 1 December 9, 2008 09:48
interpret or compile an UDF (emergency) Lotfi FLUENT 1 August 26, 2007 12:58
why results different for Compile and Interpret? Joey FLUENT 3 April 6, 2004 17:19
