question about udf for "particle surface reaction rate"
Old   January 9, 2013, 03:37
Default question about udf for "particle surface reaction rate"
leila
lili is on a distinguished road
hi
I have a problem in understanding how Fluent calculates the particle reaction rate using UDF. the define macro for it is: DEFINE_PR_RATE
in the manul it says:
"Note that a DEFINE_PR_RATE UDF is not called with the coupled solution option, so you will need to disable the Coupled Heat Mass Solution option in the Discrete Phase Model panel when using it"
so if the calculation must be done in an Uncoupled manner how the effect of reaction of gas phase is calculated? I mean for this kind of reaction a source term must be in continuous phase. isnt it?
does any one know how specious concentration changes in continuous phase is accounted on reaction rate?
thanks alot
lili is offline   Reply With Quote
[snappyHexMesh] Layers don't fully surround surface EVBUCF OpenFOAM Meshing & Mesh Conversion 14 August 20, 2012 04:31
Segmentation fault in running alternateSteadyReactingFoam,why? NewKid OpenFOAM 18 January 20, 2011 16:55
Surface Reaction Model or Heterogeneous Rxn Model? satheeskannan FLUENT 0 September 2, 2008 18:55
again on udf surface reaction jason FLUENT 0 November 7, 2003 10:45
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
