January 15, 2013, 05:22 |
UDF for inlet velocity profile
Francisco
Hi guys,
I'm using a UDF for a velocity profile to define the atmospheric boundary layer in a 2D problem. I've used the attached c code as explained in the user manual, apparently it's interpreted properly but results don't show any influence on the profile, it appears to be just a uniform velocity at the inlet (see attached picture for 5s). 1) Which can be the problem? Is there something wrong in the code? 2) What will happen if I modify the ymax coord in the code so it's higher than the domains's ymax? 3) Also I would like to use a profile for the turbulence intensity (TI), but Fluent only allows me to use it for k and epsilon. Is there a way to use TI and Turbulent Length Scale (TLS) instead of applying the formulae for (TI,TLS)(k,epsilon). 4) I will need to apply the same profile to a 3D case. It will be exactly the same in the x-y plane and constant in the z-direction. Can I use directly the same code? If not, what do I have to modify? Thanks you all! |
October 6, 2015, 12:53 |
TI Profile
Hello Bollonga: I have same problems as yours, and I see that you asked this question long time ago! so I assume you have found the answers although no one replied here. I appreciate if you could share what you found with me. My main problem is how to write a UDF to use a profile for TI of an inlet boundary condition.
If you have an example UDF, I appreciate if you share it here. Thanks, Env Quote:
March 12, 2019, 11:12 |
Edmundo
Rep Power: 11 |
June 28, 2021, 03:24 |
Turbulent boundary layer 3d problem
Gutti Lokesh Kalyan
Hello friends.
I am trying to use three velocity components code which is written in c language. Also, the Reynolds stress of R11, R21, R22, R33 was given to test the results. but I am getting wrong plots of u,v,w standard deviation, and UV Reynolds stress. I don't know what is the problem with this code. I am a beginner at coding. I guess the structure is wrong. I am using fluent software to run simulations. Could anyone help me to solve the problem in the code is attached below? Thanks in advance. |
June 29, 2021, 04:40 |
Alexander
Rep Power: 34 |
your code has 800+ line, I expect it will be hard to find person, who will debug this code instead of you
compilation log: line(53) : warning C4716: 'sort' : must return a value line(60) : warning C4715: 'findY' : not all control paths return a value functions sort and findY could have some problems, check it however, these warnings may not lead to errors.
best regards ****************************** press LIKE if this message was helpful |
inclined flat plate, inlet, turbulence profile, udf, velocity profile |
UDF problems - velocity profile | Oli | Fluent UDF and Scheme Programming | 6 | October 24, 2016 10:38 |
UDF Unsteady velocity profile | Rashad | FLUENT | 0 | February 27, 2008 14:57 |
How to specify the Velocity profile (eqn) by UDF | Anant | FLUENT | 1 | February 27, 2008 14:54 |
Multi step transient UDF velocity profile problem | William177 | FLUENT | 1 | February 3, 2008 06:47 |
UDF problem : inlet velocity in cyl. coord. system | Jongdae Kim | FLUENT | 0 | June 15, 2004 11:21 |
