udf source
Old   June 19, 2017, 04:30
Default udf source
fersim is on a distinguished road
I have a question and I will like if anyone can help me to write the following DEFINE_SOURCE:
I inform you that the values of T_mean and Time is in a txt file named result.txt.
I want to write an udf program that uses the found values of the text file.
I ran the progame and I did not find any errors but the program does not give me the values of
T_mean and Time. Help me please.
DEFINE_SOURCE(Source_AIR, c, t, dS, eqn)
real source, Time,T_mean;
FILE *pFile;
pFile=fopen("c:/result.txt","r");
fscanf(pFile,"%g %g\n",&Time,&T_mean);
fclose(pFile);
source =32*T_mean*Time;
dS[eqn] = 0.0;
return source;
fersim is offline   Reply With Quote
Old   June 19, 2017, 07:38
KaLium's Avatar
Kal-El
KaLium is on a distinguished road
-You don't give any value to T_mean
-Also this equation is odd:
TEMP=T_Mean;
source =32*T_Mean*TEMP/TIM;
T_mean*TEMP is the same as T_mean^2
Why do you even need the TEMP?
-You have not defined the T_Moyenne inside the DEFINE_SOURCE.
-You should remove the semicolon ';' from inside of fscanf(pFile,"%g ;%g\n" and fprintf(pFile,"%g ;%g\n"
-fscanf( is missing the last bracket ')'
KaLium is offline   Reply With Quote
Old   June 19, 2017, 08:08
thank you for your replay
For this Source term, I want open file text (in mu case result.txt), in this file they have a value, for exemple 30 299. (30 is 30 sec, and 299 is temperature).
for DEFINE SOURCE, I want open result.txt and read 30 as time and 299 as temperture.
Tahnk you.
FILE *pFile;
fclose(pFile);
dS[eqn] = 0.0;
return source;
Old   June 19, 2017, 08:19
KaLium's Avatar
Kal-El
still:
-T_Moyenne
-are you sure about that source-equation?
Old   June 19, 2017, 08:30
My problem is not in the equation or in the bracket (. but how can I read a file txt and load some variables (Time and Time) in the DEFINE SOURCE
Old   June 19, 2017, 08:45
KaLium's Avatar
Kal-El
Your problem was also the bracket. UDF do not work, if the code is wrong.
Do you need the "\n" when using fscanf();?
You could also try %f in your fscanf(); or are you using double precision?
Old   June 19, 2017, 09:21
not necessery to put \n or double double precision, I want juste read a text file
and calculate source =32*T_mean*Time. the values of Time and T_mean finded in the file text.
I want to have any solution to read these two values from a text file.
[swak4Foam] swak4foam for OpenFOAM 4.0 mnikku OpenFOAM Community Contributions 80 May 17, 2022 08:06
polynomial BC srv537 OpenFOAM Pre-Processing 4 December 3, 2016 09:07
[Other] How to use finite area method in official OpenFOAM 2.2.0? Detian Liu OpenFOAM Meshing & Mesh Conversion 4 November 3, 2015 03:04
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 Seroga OpenFOAM Community Contributions 9 June 12, 2015 17:18
[swak4Foam] Swak4FOAM 0.2.3 / OF2.2.x installation error FerdiFuchs OpenFOAM Community Contributions 27 April 16, 2014 15:14
