Error : CX_Interpret_String not found
Old   May 11, 2013, 17:50
Default Error : CX_Interpret_String not found
François Grégoire
macfly is on a distinguished road
I'm trying to interpret a UDF where I have the following macro, I just want to call scheme functions from a UDF:
DEFINE_EXECUTE_AT_END(execute_at_end)
CX_Interpret_String("(physical-time-steps 1 10000)");
And I get the following error when I try to interpret my UDF:
function "CX_Interpret_String" not found (pc=149)
What's wrong? Is there another way to execute text commands or scheme commands from a UDF?
Thanks,
Frank
macfly is offline   Reply With Quote
Old   May 12, 2013, 20:43
blackmask will become famous soon enough
I found in a note written by Mirko Javurek:
CX_Interpret_String("scheme-command-string") - deklariert in Fluent.Inc/fluentX.Y/cortex/src/cx.h -
interpretiert zwar den "scheme-command-string", hat aber keinen Zugriff auf das Environment.
I do not know German, either. It means "CX_Interpret_String" is declared but there is no access to the environment. Maybe you should turn to the guy who told you this function for help.
blackmask is offline   Reply With Quote
Old   May 27, 2013, 07:09
Jim Knopf
JimKnopf is on a distinguished road
did you include udf.h ? in the beginning of your UDF.
But maybe this functionallity is only available for compiled UDFs
greetz,
Jim
JimKnopf is offline   Reply With Quote
Old   May 27, 2013, 07:18
François Grégoire
Yes, I included this line at the beginning of my code: #include "udf.h"
I also thought about this possibility, and I didn't try to compile, never took the time to set everything for UDF compilation... Any 'compiler' can check this quick issue?
Frank
Old   May 27, 2013, 19:44
You need to include "cx.h" to avoid the syntax error. But again, while you can use CX_Interpret_String to do something like "display", I did not find a way to execute scheme command like 'iterate'.
Gmsh installation on terminal help spitfire Main CFD Forum 4 July 27, 2017 15:11
[Other] Mesh Importing Problem cuteapathy ANSYS Meshing & Geometry 2 June 24, 2017 05:29
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 03:01
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 07:21
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 04:26
