January 24, 2017, 02:00 |
Using UDF to define parameter
Oleg Vlasov
Rep Power: 11 |
Dear friends!
I am trying to solve transient problem. For my case I need to specify time-depended gravity, but I don't know how to do it. The only thing that I can specify for gravity is parameter. That's why my question is: how can I define the value of the parameter in UDF? I mean that the value for gravity will be changed in each time step (using real t = CURRENT_TIME). Oleg |
January 24, 2017, 02:23 |
KirMaks
Rep Power: 9 |
Hallo, You can replace Your gravity with the source in NS equations and then use source UDF to change the gravity vector with time as it is described here:
UDF to modify gravity via M_gravity[ND_ND] or DEFINE_ADJUST Best regards, Maksim |
WILLING TO PAY/ FREELANCER REQUIRED / small UDF coding force loads over body / 6DOF | acasas | CFD Freelancers | 1 | January 23, 2015 07:26 |
Please help UDF error!!!! | dinhanh | Fluent UDF and Scheme Programming | 3 | September 26, 2014 04:10 |
How to use UDF to define a moving wall | lingo | FLUENT | 9 | August 19, 2014 09:14 |
use of pointers in specific heat udf | mdakbari | Fluent UDF and Scheme Programming | 0 | April 18, 2014 11:37 |
UDF problem | libia87 | Fluent UDF and Scheme Programming | 1 | May 4, 2012 21:49 |
