Can someone help me with a UDF for a simple rotatory geometry?? |
Arthur Loginow
Rep Power: 13 ![]() |
Hello, I am trying to create a code to this geometry, as you can see at the images it is a simple geometry, it is a pipe with 2 bodies rotating inside, so far I have been reading the UDF manual, and I made a code I would like to make some questions but first here is the code:
#include "udf.h" DEFINE_CG_MOTION(Rotation,dt,vel,omega,time,dtime) { Thread *t; face_t f; /*reset velocities*/ NV_S(vel, =, 0.0); NV_S(omega, =, 0.0); /*not too sure what this is for*/ if (!Data_Valid_P()) return; /*get the thread pointer for which this motion is defines (I assume that this is the cell zone that I made)*/ t = DT_THREAD(dt); /* motion */ velocity[0] = 0; velocity[1] = 0; velocity[2] = 0; omega[0] = 0; omega[1] = 0; /*This will be just a random number, I will try different values anyway*/ omega[2] = 120; /*not sure how to do the loop and if I should make the loop for faces or cells*/ } Question 1: Do I have to create a UDF for each body? Or can I include both bodies at the same UDF? Question 2: Well as you can see at the code, I am not quite sure of how to make the loop (I have a decent programming knowledge, and because of this forced to learn C, I know how to create a loop, but I do not know what variables to include for the loop, so far I know the pointer will tell the program to use some faces/cells and that leads me to my other question) Question 3: Should I use faces or cells for the Loop? Question 4: There is something that I am missing? I read just the first 2 chapters of the UDF guide, I will finish all the guide soon, but I think that the next chapters will not clear those doubts. Thanks |
Arthur Loginow
Sorry wrong forum
Arthur Loginow
I would like to know if I should use the cells or the faces, so far I understand that I should use the faces because that will make the adjacent cells to move as well and that is what I am looking for
Paritosh Vasava
Rep Power: 22 ![]() |
Question 1: You do not need separate UDFs unless you have different rotational speed for each body. Yes you can use one UDF for several bodies.
Question 2: For simple rotational and translational motion there seem to be nothing wrong with the UDF. Instead of what you have you may use #include "udf.h" DEFINE_CG_MOTION(Rotation,dt,vel,omega,time,dtime) { /* motion */ velocity[0] = 0; velocity[1] = 0; velocity[2] = 0; omega[0] = 0; omega[1] = 0; /*This will be just a random number, I will try different values anyway*/ omega[2] = 120; /*not sure how to do the loop and if I should make the loop for faces or cells*/ } Question 3: I dont think so. Question 4: Again this is good enough for simple rotationg motion. Make sure you have your Dynamic mesh settings right. |
Arthur Loginow
Vasava thanks for your reply, sadly I have to use 2 UDF because I have the same angular velocity but in different directions, therefore I will have to create a new UDF exactly the same but with Omega[2] = -120 instead of Omega[2] = 120, anyway I will try this today and post here the experience, to help others with the same problem, thanks again.
Arthur Loginow
I will try your advice tomorrow thanks for it
Arthur Loginow
Now I am getting this error:
The UDF library you are trying to load (libudf) is not compiled for 3ddp on the current platform (win64). The system cannot find the file specified. Not idea what it is Saw different posts but none of them were solved |
Paritosh Vasava
You need to setup your visual c++ and SDK right. Here is a document that can help you.
#9 |
Arthur Loginow
Thank you Mr.Vasava you have been very helpful
#10 |
Arthur Loginow
My CMD shell says at the end v6.0 instead of v7.0, would this generate errors? Or I am able to work with this?
#11 |
Arthur Loginow
I uploaded my code and I got this warning
Rotation.c ..\..\src\Rotation.c(6) : error C2065: 'velocity' : undeclared identifier ..\..\src\Rotation.c(6) : error C2109: subscript requires array or pointer type ..\..\src\Rotation.c(7) : error C2109: subscript requires array or pointer type ..\..\src\Rotation.c(8) : error C2109: subscript requires array or pointer type I fixed the first one (pretty obvious) and I will work on the other ones. |
#12 |
Arthur Loginow
Looks like it was enough to just modify Velocity to Vel
#13 |
Arthur Loginow
When I build the udf everything is fine, when I load the library everything is fine when I save everything is fine, when I close the program and try to open the same case again I got this error from the fluent console
Auto-compilation of "libudf" failed. Please try to compile it manually. Opening library "C:\Users\Arthur\Desktop\Rotation2_files\dp0\FFF\F luent\libudf"... Error: The UDF library you are trying to load (libudf) is not compiled for 3ddp on the current platform (win64). Somehow is not working... |
#14 |
Paritosh Vasava
The error 'The UDF library you are trying....' means that your UDF has not been compiled.
The answers to 'how to fix?' lies in the errors: ..\..\src\Rotation.c(6) : error C2065: 'velocity' : undeclared identifier ..\..\src\Rotation.c(6) : error C2109: subscript requires array or pointer type ..\..\src\Rotation.c(7) : error C2109: subscript requires array or pointer type ..\..\src\Rotation.c(8) : error C2109: subscript requires array or pointer type Usually these errors even pin-point to the line where these errors occur. If you post your UDF here we can try to fix it. |
#15 |
baydu
Rep Power: 14 ![]() |
Try the following UDF, it is from the gear pump tutorial. You don't need to specify zero values because defaults are zero.
Check you that tutorial how to setup dynamic mesh parameters etc. #include "udf.h" DEFINE_CG_MOTION(object1, dt, vel, omega, time, dtime) { Domain *domain; domain = Get_Domain(1); omega[2]=-220.; } DEFINE_CG_MOTION(object2, dt, vel, omega, time, dtime) { Domain *domain; domain = Get_Domain(1); omega[2]=220.; } |
FLUENT UDF Simple error. | startup0820 | Fluent UDF and Scheme Programming | 0 | August 14, 2012 03:54 |
Need help on meshing this simple geometry | nha1g08 | ANSYS Meshing & Geometry | 3 | March 9, 2011 02:13 |
[snappyHexMesh] Irregular mesh generation for simple box geometry | ajl42 | OpenFOAM Meshing & Mesh Conversion | 0 | March 7, 2011 17:04 |
Problem with a simple UDF to calculate cell-averaged particle values | kmayank | FLUENT | 1 | January 18, 2011 01:40 |
vitual _ real | deneb | FLUENT | 3 | January 22, 2007 04:31 |
