DPM Macro for FLUENT
Old   August 14, 2013, 10:40
Default DPM Macro for FLUENT
Leepox is on a distinguished road
Hi Guys, I am currently writing a UDF.
Fluent is a bit iffy with the naming conventions so here's my Q.
I am trying to write a code for DPM_SWITCH and using particle temperature as switches. In Fluent you set the vaporisation temperature of the water and the vaporisation temperature of volatiles. But they are both called vaporisation temperatures.
In Table 3.31 in the UDF manual it only shows one DPM_VAPOR_TEMP and I assume that is to do with the set devolatilisation temperatures. Instead the DPM_EVAPORATION_TEMPERATURE is the vaporisation temperature for water.
Can anywone confirm this? Thanks!
Leepox is offline   Reply With Quote
DPM Output Problem (Again...) DLINSA Fluent UDF and Scheme Programming 1 March 16, 2012 00:45
DPM concentration macro?? Yurong FLUENT 10 November 16, 2011 23:30
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 01:29
URGENT - DPM Macro for custom bc cfd-user FLUENT 2 July 21, 2008 11:26
Macro problem cfddummy Siemens 1 April 9, 2007 12:37
