Need UDF for Mixture Model
Old   January 16, 2012, 01:53
Default Need UDF for Mixture Model
Vaibhav Rai Khare
vaibhavraikhare is on a distinguished road
I am working on heat and mass transfer of mixture model.and need to know how the UDF file will be made???
can any 1 provide its sample of any tutorial file???
vaibhavraikhare is offline   Reply With Quote
Old   January 17, 2012, 08:22
Default hi
shoeb khan
shk12345 is on a distinguished road
For heat transfer i think that there is no need of any udf as such .
You just define the temperature at some wall it has to work.
You need a udf for masss transfer which you can find in ansys udf manual that is available on net.You just copy paste that and just change the mass transfer equation to the equation that is needed for your work.
Thanks
shk
shk12345 is offline   Reply With Quote
Old   January 17, 2012, 09:29
Real Name :)
ComputerGuy is on a distinguished road
I would not specify the temperature directly, as suggested by shk12345; this is asking for simulation instabilities. I would allow fluent to calculate it for you. See example 2 for how to define heat transfer between phases: http://my.fit.edu/itresources/manual...udf/node61.htm
See the example here for mass transfer:
http://my.fit.edu/itresources/manual...udf/node63.htm
ComputerGuy
ComputerGuy is offline   Reply With Quote
Old   January 17, 2012, 09:34
shoeb khan
The first link that you shared is drag law used by multiphase models as eulerian model and mixture model . That is not for temperature specifications.
For mass transfer as i said to you you can copy that udf and change it with your mass transfer equation in the MT equation used in that udf.
regards
shk
Old   January 17, 2012, 09:36
Real Name :)
OK -- if the mixture model is used (was thinking Eulerian), all phases have the same temperature. I stand corrected! Temperature must be specified; be careful.
FYI: If you choose to use the Eulerian model, the heat transfer law is on the page provided as follows:
#include "udf.h"
#define PR_NUMBER(cp,mu,k) ((cp)*(mu)/(k))
#define IP_HEAT_COEFF(vof,k,nu,d) ((vof)*6.*(k)*(Nu)/(d)/(d))
static real
heat_ranz_marshall(cell_t c, Thread *ti, Thread *tj)
 real h;
 real d = C_PHASE_DIAMETER(c,tj);
 real k = C_K_L(c,ti);
 real NV_VEC(v), vel, Re, Pr, Nu;
 NV_DD(v,=,C_U(c,tj),C_V(c,tj),C_W(c,tj),-,C_U(c,ti),C_V(c,ti),C_W(c,ti));
 vel = NV_MAG(v);
 Re = RE_NUMBER(C_R(c,ti),vel,d,C_MU_L(c,ti));
 Pr = PR_NUMBER (C_CP(c,ti),C_MU_L(c,ti),k);
 Nu = 2. + 0.6*sqrt(Re)*pow(Pr,1./3.);
 h = IP_HEAT_COEFF(C_VOF(c,tj),k,Nu,d);
return h;
DEFINE_EXCHANGE_PROPERTY(heat_udf, c, t, i, j)
  Thread *ti = THREAD_SUB_THREAD(t,i);
  Thread *tj = THREAD_SUB_THREAD(t,j);
  real val;
  val = heat_ranz_marshall(c,ti, tj);
  return val;
Old   January 17, 2012, 09:50
shoeb khan
Thanks for that udf
that is ranz marshal law in eulerian model in fluent.
""The default heat transfer option between the continuous phase and the particles is Ranz Marshall. The Ranz Marshall correlation is also applicable to Eulerian multiphase flow."" /quote/
http://www.kxcad.net/ansys/ANSYS_CFX...h07s05s03.html
it is not for temperature but for h eat transfer between the phase and you need not to put it as udf in fluent it is already build in fluent.
thanks and regards
shk
Old   March 2, 2013, 21:28
cfd^2
cfd^2 is on a distinguished road
#include "udf.h"
static real
 real h;
 vel = NV_MAG(v);
return h;
  real val;
  return val;
Sir ComputerGuy,
Is this piece of code the one that is implemented in FLUENT to calculate the heat transfer coefficient by Ranz-Marshall model? If yes, it is really interesting, since I'll be able to change a few things and redefine it as a User Defined parameter in the interaction panel for heat transfer in multiphase simulation...
Best Regards,
cfd^2
cfd^2 is offline   Reply With Quote
Old   September 4, 2013, 23:03
C
Raining is on a distinguished road
#include "udf.h"
static real
 real h;
 vel = NV_MAG(v);
return h;
  real val;
  return val;
Any result based on this UDF?
Raining is offline   Reply With Quote
Writing UDF for Eulerian model golriz Fluent UDF and Scheme Programming 7 November 3, 2011 05:30
UDF for Heat Exchanger model francois louw FLUENT 2 July 16, 2010 02:21
Modifying Pressure swirl atomizer model by UDF jeff_F FLUENT 0 May 22, 2010 09:22
UDF: how to know domain number in the model? mssound FLUENT 0 May 17, 2010 15:00
The problem of UDF in Non premixed combustion model zhangyuan Main CFD Forum 0 May 25, 2009 09:41
