November 18, 2017, 07:33 |
define source term
behzad
Rep Power: 9 |
hi everyone
i have a serious problem in fluent what is the udf for permeate flux?...i have to modeling a tube that have an inlet and outlet, but the walls of tube have permeability. indeed i want to model a membrane that fluid enters the inlet and a little bit of fluid passes through the wall(i know the equation for permeability) and rejected fluid is exited from the outlet. so can anyone tell me how can i define a udf for this equation please?..i realized i have to use sink & source method for wall boundary condition, also i have to use "define_source" macro. but i didn't see examples for this section. i don't know how to write udf for this boundary!!. thank you |
[swak4Foam] swak4foam for OpenFOAM 4.0 | mnikku | OpenFOAM Community Contributions | 80 | May 17, 2022 08:06 |
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 | ordinary | OpenFOAM Installation | 19 | September 3, 2019 18:13 |
what is swap4foam ?? | AB08 | OpenFOAM | 28 | February 2, 2016 01:22 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
