how to load UDF in parallel at linux platform |
September 22, 2013, 21:56 |
maye
The UDF is built and loaded well in windows platform by installing VC++. But when I do the same thing in suse linux or redhat linux, it works well in serial simulation but loading failed in parallel simulation. The hint shows:
The UDF library you are trying to load (libudf/inamd64/3d_host/libudf.so) is not compiled for parallel use on the current platform (lnamd64) no error /cae/maye/fluent/test/libudf/lnamd64/3d_host/libudf.so All gcc (C++&Fortran) of x86_64 has been installed. How can I solve the problem? Shall I install more codes or set any environments? The UDF file is: #include <stdio.h> #include "udf.h" DEFINE_CG_MOTION(wall, dt, vel, omega, time, dtime) { if(time<=8.0) { vel[2]=-0.75*time; } if(time>8.0&&time<=14.0) { vel[2]=-6.0; } if(time>14.0&&time<=22.0) { vel[2]=-6.0+0.75*(time-14.0); } if(time>22.0) { vel[2]=0.0; } Message("\nUDF value: velx=%f",vel[2]); } |
September 23, 2013, 06:58 |
Christopher Hershey
You need to add compiler directives into your UDF. These go something like this:
#if RP_HOST /*enter code here*/ #endif or #if RP_NODE /*enter code here*/ #endif There are others, but I suggest reading through the manual first. This should help you too: http://aerojet.engr.ucdavis.edu/flue...df/node207.htm |
September 23, 2013, 21:44 |
maye
THX!
I tried to modify the UDF file as follows, but the error still there: #include <stdio.h> #include "udf.h" DEFINE_CG_MOTION(wall, dt, vel, omega, time, dtime) { #if RP_NODE if(time<=8.0) { vel[2]=-0.75*time; } if(time>8.0&&time<=14.0) { vel[2]=-6.0; } if(time>14.0&&time<=22.0) { vel[2]=-6.0+0.75*(time-14.0); } if(time>22.0) { vel[2]=0.0; } #endif #if RP_HOST Message("\nUDF value: velx=%f",vel[2]); #endif } How to solve it? |
September 23, 2013, 22:02 |
maye
When I click load, the following errors show:
Node 0: Doesn't have write permissions for libudf/lnamd64/3d_node. If using local disk, make sure UDF lib is synced up on all nodes. Opening library "/mnt/test/libudf"... Primitive Error at Node 1: The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform (lnamd64). No such file or directory /ansys_inc/v145/fluent/bin/libudf/lnamd64/3d_node/libudf.so Primitive error at Node 0: The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform (lnamd64). No such file or directory /ansys_inc/v145/fluent/bin/libudf/lnam64/3d_node/libudf.so Opening library "/ansys_inc/v145/fluent/bin/libudf"... Opening library "/ansys_inc/v145/fluent/bin/libudf"... Error: The UDF library you are trying to load (libudf/lnam64/3d_host/libudf.so) is not compiled for parallel use on the current platform (lnamd64). no error /mnt3/test/libudf/lnamd64/3d_host/libudf.so Error Object: #f |
April 21, 2014, 14:04 |
I am also experiencing the same issue. May I know have you figured out the solution?
April 6, 2018, 14:31 |
Felipe
Rep Power: 8 |
I am also experiencing the same issue. Have you figured out how to solve this problem?
April 10, 2018, 07:26 |
Felipe
Rep Power: 8 |
@maye761, were you using normal or superuser login when you experienced this problem?
I got the same error, even after inserting some compiler directives on the code. If you solve this problem, could you share the way, please? Thank you. |
April 12, 2018, 07:53 |
André Domingues
Rep Power: 8 |
Hi, try like this. I'm not a coding expert but maybe it will work.
#include <stdio.h> #include "udf.h" DEFINE_CG_MOTION(wall, dt, vel, omega, time, dtime) { #if !RP_HOST if(time<=8.0) { vel[2]=-0.75*time; } if(time>8.0&&time<=14.0) { vel[2]=-6.0; } if(time>14.0&&time<=22.0) { vel[2]=-6.0+0.75*(time-14.0); } if(time>22.0) { vel[2]=0.0; } #endif #if !RP_HOST Message("\nUDF value: velx=%f",vel[2]); #endif } |
April 13, 2018, 03:28 |
Rep Power: 11 |
Regardless of anything else, this is a much better structure:
if(time<=8.0) { vel[2]=-0.75*time; } else if(time<=14.0) { vel[2]=-6.0; } else if(time<=22.0) { vel[2]=-6.0+0.75*(time-14.0); } else { vel[2]=0.0; } |
April 13, 2018, 03:30 |
Rep Power: 11 |
And it does not take a lot of effort to add parameters that can be varied later:
#define PLATEAU_VEL -6.0 #define PLATEAU_TIME_START 8.0 #define PLATEAU_TIME_END 14.0 #define PLATEAU_DURATION_RAMPDOWN 8.0 if(time<=PLATEAU_TIME_START) { vel[2]= time * (PLATEAU_VEL/PLATEAU_TIME_START); } else if(time<=PLATEAU_TIME_END) { vel[2]= PLATEAU_VEL; } else if(time<= (PLATEAU_TIME_END+PLATEAU_DURATION_RAMPDOWN)) { vel[2]= PLATEAU_VEL * (1.0 - (time - PLATEAU_TIME_END)/PLATEAU_DURATION_RAMPDOWN); } else { vel[2]=0.0; } |
Problem in using UDF in parallel computing | Yogini | Fluent UDF and Scheme Programming | 0 | January 22, 2013 08:23 |
Dynamic Mesh- Parallel UDF | DE HEART | Fluent UDF and Scheme Programming | 14 | August 11, 2010 01:29 |
parallel udf problem in linux | endlessfree | Fluent UDF and Scheme Programming | 0 | April 13, 2010 10:19 |
Help with Define on Demand UDF in Parallel | Mahesh | FLUENT | 2 | August 7, 2007 05:34 |
CFX, NT parallel, Linux, best platform | Heiko Gerhauser | CFX | 1 | August 21, 2001 09:46 |
