Using Density Gradient C_R_G(c,t), Pressure Based Solver
Old   February 21, 2011, 12:47
Exclamation Using Density Gradient C_R_G(c,t), Pressure Based Solver
Andeo
Anirudh_Deodhar is on a distinguished road
Hi all
I am using VOF method in Fluent to model air-water bubble. I need to use the density gradient inside the bubble interface (where 0 < volume fraction < 1) to write one of the source terms in an equation.
But Fluent doesn't allow me to use "C_R_G(c,t)" macro as I am using Pressure Based solver.
Is there a way to make C_R_G work in pressure based solver using some extra text command or anything else?
Or anybody aware of any other macro to calculate density gradient in the cells in interface region.
Thanks,
Anirudh
Anirudh_Deodhar is offline   Reply With Quote
Old   October 25, 2013, 05:43
Ahmet Yıldız
Isandor is on a distinguished road
I am experiencing exactly the same problem. Is there a way to calculate the density gradient in pressure based solver? Is there a workaround or something like that?
Thanks in advance.
Isandor is offline   Reply With Quote
c_r_g, density gradient, pressure based solver
NRBC and pressure based solver ageorg FLUENT 1 August 28, 2009 07:11
Solver and density function for high speed vapour christian OpenFOAM Running, Solving & CFD 17 April 12, 2007 02:41
pressure and density based solvers sun Main CFD Forum 0 November 8, 2004 06:20
Pressure vs Density based CFD solvers Danie Main CFD Forum 0 October 5, 2004 09:48
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
