interpret UDF Error????
Old   October 25, 2013, 04:52
Question interpret UDF Error????
hadi
h.iraji is on a distinguished road
Hi
I have been a udf as follow:
#include "udf.h"
#include "mem.h"
DEFINE_GEOM(deforming,domain,dt,position)
cell_t c;
Thread *t;
real *position;
begin_c_loop_all(c,t)
position=0.2601*exp(-6.147e-05*C_P(c,t)) + 0.5091*exp(-0.0007079*C_P(c,t));
end_c_loop_all(c,t)
return;
After trying to interpret it, error reports was seen as follow:
Error: line 10: invalid type for pointer dereference: float.
How eliminate these error?
Anyhelp would be appreciated.
h.iraji is offline   Reply With Quote
Old   October 26, 2013, 18:05
A CFD free user's Avatar
A-A Azarafza
A CFD free user is on a distinguished road
It seems that Fluent considers simple variable in equation as pointer. You can rearrange the equation. For instance, instead of 0.5*C_P(c,t), you'd better use C_P(c,t)*0.5.
I had the same error before. You need to do something like that.
Regard yours
A CFD free user is offline   Reply With Quote
Old   October 27, 2013, 09:31
Default ???????
hadi
Thanks a lot for your Answer
I want to deforming thickness variations of the pressure plate in each cell(Cells of the upper face plate):
y=0.2601*exp(-6.147e-X*0.5) + 0.5091*exp(X*(-0.0007079))
(X=pressure , Y= thickness variation).
for this purpose i writed below udf but incorect:
#include "udf.h"
#include "mem.h"
cell_t c;
Thread *t;
real *position;
position=0.2601*exp(-6.147e-C_P(c,t)*0.5) + 0.5091*exp(C_P(c,t)*(-0.0007079));
end_c_loop_all(c,t)
return;
Error: line 10: parse error
can anyone help me in regarding with above problem….
thanks
Old   October 27, 2013, 12:32
A-A Azarafza
It sounds that you've made mistaken in writing equation. I think, the problem is in the " -6.147e-C_P(c,t) " . what's "e -C_P(c,t) " here. Have a deeper look at correct it.
Regard yours
Old   October 28, 2013, 03:52
Smile
hadi
oh.yes.
Tanks
[OpenFOAM] an error in Calculator's equation immortality ParaView 12 June 29, 2021 00:10
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 00:21
[General] 2 datas on one plot Akuji ParaView 46 December 1, 2013 14:06
Errors in UDF shashank312 Fluent UDF and Scheme Programming 6 May 30, 2013 20:30
How to get the max value of the whole field waynezw0618 OpenFOAM Running, Solving & CFD 4 June 17, 2008 05:07
