November 20, 2013, 03:57 |
Set velocity to zero?
Select One...
Rep Power: 14 |
My problem is the following:
First I solve momentum equation and obtain velocity field (steady state). After that I turn on energy eq. for transient simulation and turn off momentum eq. During my transient simulation (heat transfer) I'd like that the velocity is 0 for a while (there is a condition when this happens), and after that it should be again as it was after steady state calculation. I would be more than happy if anyone could suggest how to do that! If this is not possible, is it possible to turn off energy equation, when the condition is fulfilled (but not manually, because it is a parametric analysis, therefore it should be automatically). |
change velocity, heat transfer, momentum equation |
set velocity of a droplet | liping_he | FLOW-3D | 0 | November 20, 2012 09:33 |
How to set phases with different velocity | kbaker | CFX | 16 | May 5, 2012 07:25 |
can i set the velocity and pressure at the inlet at the same time by UDF | minyang.cau | FLUENT | 0 | July 14, 2009 23:14 |
Velocity in Porous medium : HELP! HELP! HELP! | Kali Sanjay | Phoenics | 0 | November 6, 2006 06:10 |
How to set transient ang velocity? | edi ghirardi | FLUENT | 0 | April 12, 2005 09:34 |
