Error: The UDF library you are trying to load is not compiled for 3ddp on the current
Prev Previous Post   Next Post Next
Old   November 21, 2013, 06:45
Default Error: The UDF library you are trying to load is not compiled for 3ddp on the current
Josiah Sng
Whitemast is on a distinguished road
Hi, I am currently doing an analysis on UV water treatment. I want to calculate the UV dose travelling through a UV chamber.
I downloaded a UDF from this website: http://www.sandia.gov/cfd-water/uvdi...tion.htm#tools and tried to load it in Ansys fluent using the instructions provided.
I tried using both the UDF for parallel and serial, but it always comes up with an error.
I got this error message:
Opening library "D:\University\FYP\Ansys tutorials\Current coding project\try_ok_files\dp0\FLU\Fluent\D:\University\ FYP\Ansys tutorials\Current coding project\try_ok_files\dp0\FLU\Fluent\libudf"...
Error: The UDF library you are trying to load (D:\University\FYP\Ansys tutorials\Current coding project ry_ok_files\dp0\FLU\Fluent\libudf) is not compiled for 3ddp on the current platform (win64).
The system cannot find the path specified.
D:\University\FYP\Ansys tutorials\Current coding project ry_ok_files\dp0\FLU\Fluent\D:\University\FYP\Ansys tutorials\Current coding project ry_ok_files\dp0\FLU\Fluent\libudf\win64\3ddp\libud f.dll
Error Object: #f
Is it possible that someone can give me suggestions on what I am doing wrongly?
I am currently using ansys Fluent 14.5 on windows 8 64bit.
I read on the forums that I need an SDK 7.1 to do the compilation. Is that related to my current problem? Where can I download it?
I just installed Microsoft .NET Framework 4.5 SDK is it the same as SDK 7.1?
Whitemast is offline   Reply With Quote
Current density visualisation (PEM fuel cell add-on module) pchoopanya FLUENT 10 August 21, 2023 14:33
Compiled library vs. inInclude Files, DSMC solver crashes after run GPesch OpenFOAM Programming & Development 8 April 18, 2013 07:17
calling result of a UDF into current time step Komon Fluent UDF and Scheme Programming 1 April 1, 2012 19:53
cannot load UDF library jayilosa Fluent UDF and Scheme Programming 3 November 16, 2011 12:44
building compiled udf s in windows sourav FLUENT 8 August 18, 2005 01:46
