6dof udf
Like Tree1Likes
  • 1 Post By assac
Old   March 3, 2012, 20:41
Unhappy 6dof udf
assac is on a distinguished road
Hi, I have a question:
I wanna calculate the movement of a 3d rigid body due to the pressure and shear forces of the flow with Fluent. The problem is a 3d flow in a tube with a rigid body that is free to move inside that tube (I've added an image below).
I wrote this UDF (It's my first UDF!!!! :-S ):
DEFINE_SDOF_PROPERTIES(six_degs_of_frdom1, prop, dt, time, dtime)
Thread *t;
face_t f;
real NV_VEC(A);
real force0, force1, force2;
t = DT_THREAD(dt);
force0 = 0.0;
force1 = 0.0;
force2 = 0.0;
begin_f_loop(f,t)
F_AREA(A,f,t);
force0 += F_P(f,t) * A[0] + F_STORAGE_R_N3V(f,t,SV_WALL_SHEAR)[0];
force1 += F_P(f,t) * A[1] + F_STORAGE_R_N3V(f,t,SV_WALL_SHEAR)[1];
force2 += F_P(f,t) * A[2] + F_STORAGE_R_N3V(f,t,SV_WALL_SHEAR)[2];
end_f_loop(f,t)
prop[SDOF_MASS] = 50;
prop[SDOF_LOAD_F_X] = force0; /* external force */
prop[SDOF_LOAD_F_Y] = force1; /* external force */
prop[SDOF_LOAD_F_Z] = force2; /* external force */
but Fluent stamp an error :
Error:
FLUENT received fatal signal (ACCESS_VIOLATION)
1. Note exact events leading to error.
2. Save case/data under new name.
3. Exit program and restart to continue.
4. Report error to your distributor.
Error Object: #f
Can somebody help me??!?!?!??!?!
Thanks!
[IMG][img=http://s16.postimage.org/51n8m75sl/problem.jpg] png image hosting[/IMG]
joy2000 likes this.
assac is offline   Reply With Quote
Old   March 6, 2012, 13:38
Red face solution
I've added this header:
storage.h
and the "ACCESS_VIOLATION" problem was solved!! (many thanks to Amir for that!).
But there is now a new problem...
the 3d object doesn't move at all...
does anyone have any idea what might be wrong?
Thanks!
Old   January 23, 2014, 09:19
Default help!
majid
majidmng is on a distinguished road
Hi assac
im using 6dof for calculate force and moving body
my udf is:
#include "udf.h"
DEFINE_SDOF_PROPERTIES(stage, prop, dt, time, dtime)
Thread *t;
face_t f;
real NV_VEC(A);
t = DT_THREAD(dt);
force0 = 0.0;
force1 = 0.0;
force2 = 0.0;
begin_f_loop(f,t)
F_AREA(A,f,t);
force0 += F_P(f,t) * A[0];
force1 += F_P(f,t) * A[1];
force2 += F_P(f,t) * A[2];
end_f_loop(f,t)
printf ("\nstage: updated 6DOF properties");
but it doesnt work and fluent messege is:
Error Object: ()
please help me.
majidmng is offline   Reply With Quote
access violation error, moving body, moving mesh, sixdofrigidbody, sixdofsolver
Problem with 6DOF udf rafasdo Fluent UDF and Scheme Programming 2 August 9, 2014 10:39
would someone give me a example of udf for 6DOF? conan FLUENT 3 January 24, 2011 21:10
sharing the directory for parallel 6DOF UDF... usman naseer Main CFD Forum 1 September 6, 2010 04:09
parallel 6DOF UDF.... usman naseer FLUENT 1 February 18, 2010 14:56
6DOF UDF: Obtain CG velocity NRD FLUENT 0 February 27, 2008 11:36
