someone help me please with my UDF
Old   January 10, 2011, 02:25
Default someone help me please with my UDF
EH
ehooi is on a distinguished road
Hi all.
I have written a UDF that calculates the mean temperature of the outflow that is to be supplied to the inlet (something like a recirculation tank). When I compiled the UDF (UDFtrial.c), the following messages appear:
Error Object: #f
Deleted old libudf\win64\3ddp_host\libudf.dll
libudf\win64\3ddp_node\libudf.dll
1 file(s) copied.
(system "copy "C:\PROGRA~1\ANSYSI~1\v121\fluent"\fluent12.1.4\sr c\makefile_nt.udf libudf\win64\3ddp_host\makefile")
1 file(s) copied.
(chdir "libudf")()
(chdir "win64\3ddp_host")()
# Generating ud_io1.h
(system "copy "C:\PROGRA~1\ANSYSI~1\v121\fluent"\fluent12.1.4\sr c\makefile_nt.udf libudf\win64\3ddp_node\makefile")
1 file(s) copied.
(chdir "libudf")()
(chdir "win64\3ddp_node")()
and not the message as suggested by the UDF manual to be a successful compilation. Loading the library led to this error:
Opening library "libudf"...
Primitive Error at Node 0: open_udf_library: The operation completed successfully.
Primitive Error at Node 1: open_udf_library: The system cannot find the file specified.
Primitive Error at Node 2: open_udf_library: The system cannot find the file specified.
Primitive Error at Node 3: open_udf_library: The system cannot find the file specified.
Error: open_udf_library: The operation completed successfully.
Error Object: #f
I am running FLuent on a Windows 7 64bit system and parallel on a local machine.
Can someone help me with this?
Many thanks.
EH
ehooi is offline   Reply With Quote
Old   January 12, 2011, 21:32
gearboy is on a distinguished road
Originally Posted by ehooi View Post
Hi all.
Error Object: #f
1 file(s) copied.
1 file(s) copied.
(chdir "libudf")()
1 file(s) copied.
(chdir "libudf")()
Error Object: #f
Many thanks.
EH
Do not put the case and udf source file in the folder with a blank, such as "Program files"
gearboy is offline   Reply With Quote
Old   January 13, 2011, 02:02
EH
Thanks for your reply but the case file and the udf are in a path that does not contain spaces.
D:\USERS\EHOOI\Fluent\SONO\FLUENT_EH\Fabric_100_10 Jan
I have been trying to solve this issue for some time now and any help will be gratefully appreciated.
Old   January 13, 2011, 10:55
There is a space in "Fabric_100_10 Jan", right?between "Fabric_100_10" and "Jan".
Old   January 13, 2011, 11:02
EH
There is no space there. Sorry for the mistake there. The directory is:
which has no space.
I have no idea what is wrong.
Old   January 13, 2011, 20:40
which has no space.
Another possibility is that you install ansys under "Program files", which has a space.
Old   January 14, 2011, 05:20
EH
Thanks for your reply. Yes Ansys is installed in
C:\Program Files\ANSYS Inc
There are spaces in Program Files and Ansys Inc. Are you saying that the spaces will cause error when trying to run parallel UDF?
But ANSYS Inc is a default folder created by ansys....does it mean I would have to change that as well?
Thanks.
EH
Old   January 17, 2011, 08:58
Thanks.
EH
I have never try ansys 12. Just give you some idea.
Old   September 27, 2011, 03:01
Default Please let me know about the outcome
Ehsan
Ehsan-F is on a distinguished road
Ehooi,
I have the same problem with the same error. Ansys is installed in "program file"
please let me know if you could find the answer.
it take me more than 2 weeks but still no progress.
Ehsan
Ehsan-F is offline   Reply With Quote
Old   September 27, 2011, 03:09
EH
Originally Posted by Ehsan-F View Post
Ehooi,
Ehsan
You have to install Microsoft Windows SDK 7.1 Command Prompt and run Fluent from there. Also use Microsoft Visual C++ 2010 Express.
Hope this helps
Old   September 27, 2011, 03:14
EH
Ehooi,
Ehsan
I attached another file containing some help. I couldn't get this to work in mine but maybe it will help in your case. The way I did it was mentioned in my earlier reply to you.
Old   September 27, 2011, 03:33
Ehsan
Thanks for your quick reply,
I will try that and see if helps. have you installed first visual c++ then fluent or it does not any matter? and then install SDK.
Thanks
Ehsan
Old   September 27, 2011, 03:35
EH
I will try that ans see if helps. have you installed first visual c++ then fluent or it does not any matter? and then SDK.
Thanks
Ehsan
Fluent can be installed first, that doesnt matter. But in terms of visual c++ and SDK, I dont remember but I think installing C++ first will make more sense. Just give it a try.
Old   September 27, 2011, 04:07
Ehsan
Hi Ehooi,
thanks for sending pdf; seems it is not working,
I have installed C++ 2010 express edition and SDK 7.1
Thanks , it can be built now but I cannot load it.
the error is:
Errorpen_udf_library:The system cannot find the file specified.
have you set environment variables for c++ and fluent before you get them working? what you added to your path?
I have added these three:
C:\Program Files (x86)\Microsoft Visual Studio 10.0\Common7\Tools;C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\bin;C:\Program Files\ANSYS Inc\v120\fluent\ntbin\win64
please let me know if you have any comment on that
Many thanks
EHsan
Old   September 27, 2011, 06:15
EH
Hi Ehooi,
the error is:
Many thanks
EHsan
Sorry I can't remember how I did it. But could you give me more information as in where is it that they asked you to set the path for the environment variables? Maybe that will jog my memory.
Old   September 27, 2011, 12:40
Ehsan
It works now, I just changed the file name from "gas nozzle" to "nozzle" then it works.
Thanks alot for all your helps
Ehsan
Old   November 2, 2011, 02:33
Mohsin Mukhtar
Mohsin is on a distinguished road
Dear Ehsan,
I have got exactly same problem.
Could you tell me which file name you had changed? Case and Data file names? Apparently it seems that they shouldn't have a space between them but mine has no space still i am getting the error. Any suggestion?
Greatly thanks
Mohsin is offline   Reply With Quote
Old   November 2, 2011, 02:45
Ehsan
Hi Mohsin,
I have attached a file containing what I have done, see that may help you.
The source file should not have space in its name but your problem maybe different, check the file
Ehsan
Old   November 2, 2011, 20:53
Mohsin Mukhtar
Dear Ehsan,
Thanks alot. Problem solved.
Old   January 27, 2014, 13:07
Kieran
Kxt908 is on a distinguished road
I encountered the same problem. I made a new workbench case without any spaces in its name and everything seemed to work OK.
Kxt908 is offline   Reply With Quote
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 07:37
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 21:38
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 04:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 04:01
