February 2, 2014, 12:11 |
Writing txt file in an UDF
Sayan Bose
Rep Power: 13 |
I want to write the particle accelerations in a separate txt file, in a DPM_BODY_FORCE UDF, by performing a file operation, to do that I added this few line in the DPM body force UDF, which logically should have worked.
But after loading the udf, when I am executing calculation fluent is getting closed when the particle update is about to happen, and the txt files created doe not have any thing in them, they are just blank. This is the code, which just show the file operation part along with the conventional DPM body force codes, please tell me where I have gone wrong and what should I do to correct it. DEFINE_DPM_BODY_FORCE(particle_body_force,p,i) { FILE *x_comp; FILE *y_comp; FILE *z_comp; real bforce,bforcex,bforcey,bforcez; x_comp=fopen("x-comp.txt","w"); y_comp=fopen("y-comp.txt","w"); z_comp=fopen("z-comp.txt","w"); x=P_POS(p)[0]-xmag; y=P_POS(p)[1]-ymag; z=P_POS(p)[2]-zmag; modr=............................................. ........ ................................Denomx; if(i==0.) { bforcex=bforce*unitsx; Ax = bforcex/P_MASS(p); fprintf(x_comp,"%g\t\n",Ax); } else if(i==1.) { bforcey=bforce*unitsy; Ay = bforcey/P_MASS(p); fprintf(y_comp,"%g\t\n",Ay); } else if(i==2.) { bforcez=bforce*unitsz; Az = bforcez/P_MASS(p); fprintf(z_comp,"%g\t\n",Az); } return((bforce)/P_MASS(p)); fclose(x_comp); fclose(y_comp); fclose(z_comp); } |
February 3, 2014, 07:52 |
Rep Power: 26 |
It can be that you still have the files opened in some editor (notepad or whatever). I think I did that once and then Fluent also shut down without warning.
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
how to calculate mass flow rate on patches and summation of that during the run? | immortality | OpenFOAM Post-Processing | 104 | February 16, 2021 08:46 |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 03:23 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
