RP_variable for porous information
Old   February 4, 2014, 06:40
Default RP_variable for porous information
crevoise is on a distinguished road
Hello
I am trying to access information about my porous media
I was wondering how to get the 'porosity' value in my udf?
I have tried stuff like:
por = RP_Get_Real("porosity");
por = RP_Get_Real("fluid-porosity");
etc...
but it does not seems such variable exits as a Fluent variable.
Does anyone knows how to access the list of Fluent variables?
I am trying to access such data in order to deal with a porous media only.
In an interpreted UDF, I am writing such loop (for example for the intialization) (let say I have 2 fluid threads and 1 solid thread, one fluid thread being porous):
DEFINE_INIT(init, d)
Thread *t;
cell_t c;
thread_loop_c(t,d)
     if (NNULP(T_STORAGE_R(t,SV_P)  // to get the fluid threads
        // here I wish to get only the porous one, so that explain my above
        question:
        if porosity = 1, etc....
Alternatively, in a compiled UDF, I have wrote the following:
real cporous;
Thread *t;
cell_t c;
thread_loop_c(t,d)
     if (FLUID_THREAD_P(t) && THREAD_VAR(t).fluid.porous)
          begin_c_loop(c,t)
               cporous = cporous + 1;
          end_c_loop(c,t)
but it seems this return the total amount of the fluid cells, both the fluid and the porous.
I do not really understand why the THREAD_Var(t).fuid.porous does not work in the compiled udf.
After several unfruitful tests, I decided to try the way by the interpreted udf (and then the problem on getting the porosity value came, as the THREAD_VAR can be used only in compiled udf).
Thank you for any hint on that problem
crevoise is offline   Reply With Quote
Old   July 22, 2017, 12:42
Estêvão Lannes Tolentino
estevaotolentino is on a distinguished road
Hi Mr. Crevoise,
I'm having a similar problem. Did you solve the problem of your compiled UDF code ? Were you able to correctly use the terms "FLUID_THREAD_P(t) && THREAD_VAR(t).fluid.porous" ?
Thank you.
estevaotolentino is offline   Reply With Quote
porous, thread, udf
ERROR #001100279 has occurred in subroutine ErrAction. smnaryal CFX 11 December 20, 2017 16:32
using face information in a cell-based macro ximik Main CFD Forum 2 May 10, 2011 17:42
interchanging face information with cell information/ radiation flux UDF ximik FLUENT 1 May 4, 2011 16:34
PHOENICS Information Peter Spalding Phoenics 0 September 24, 2004 05:30
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
