udf for heatflux to be applied on a horizontal plate
Like Tree1Likes
  • 1 Post By ghost82
Old   March 22, 2014, 08:36
Default udf for heatflux to be applied on a horizontal plate
vipinmace is on a distinguished road
hi friends
i need a little favour asap.I've to apply a heat flux equation on the top edge of a horizontal plate(50 micro m * 50 micro m ) . I'm really new to fluent as i was working on APDL.I find it difficult to apply this function in APDL so i'm trying FLUENT . THIS IS MY PROBLEM
from starting of the edge ,up to a length of 20 micro meter , heat flux is
4.41 * e^(x^2 ) , where x represents length along the edge.
Then from 20 micrometer on wards upto the end of the edge equation is h*(T - 298 ), where h is constant and T is the temperature at the end of each iteration .
Please help me on this.
vipinmace is offline   Reply With Quote
Old   March 23, 2014, 14:53
François Grégoire
macfly is on a distinguished road
I only have a partial answer.
What you need is a DEFINE_PROFILE macro, see the Ansys Fluent UDF Manual 15.0: Section 2.3.19.3. Example 1 - Pressure Profile. It's a straightforward example showing how you can apply a position-dependent profile.
The problem in your case is that you want to define a heat flux boundary condition when x <= 20 µm, and a convection boundary condition elsewhere. I'm not sure if you can do that. Maybe someone else can help you with that.
macfly is offline   Reply With Quote
Old   March 24, 2014, 05:40
ghost82's Avatar
Rick
ghost82 will become famous soon enough
You can do it, use define_profile as macfly suggested.
You have to work in pre-processing; if you want to apply 2 different boundary conditions on the top edge, simply split the top edge into two parts and assign 2 different names for that walls; then in fluent you will assign the udf for heat flux f(x) to one wall and the other boundary condition to the second one.
Daniele
macfly likes this.
ghost82 is offline   Reply With Quote
FSI oscillating plate spatialtime CFX 4 April 29, 2009 15:04
heat transfer on dimpled plate mech FLUENT 4 February 6, 2007 15:15
UDF for heat flux applied during T seconds nazeem FLUENT 0 June 22, 2004 05:26
UDF for a heat flux applied during T second on a w nazeem FLUENT 0 June 12, 2004 10:28
DEFINE_ON_DEMAND UDF: How to declare A[ND_ND], etc jx FLUENT 1 November 6, 2003 17:23
