problem with real number in udf
Old   April 1, 2014, 14:38
Default problem with real number in udf
amr mobarez
amr mobarez is on a distinguished road
hi guys i'm making udf for unsteady inlet velocity ( step train ) with certain value
with respect to time but i having problem with direction and magnitude as some of the flow goes into the reverse direction here is the code i wrote i hope someone can tell me what is wrong with it
#include "udf.h"
DEFINE_PROFILE(unsteady_x_velocity, thread, position)
face_t f;
real t = CURRENT_TIME;
if(t < 0.1)
F_PROFILE (f, thread, position)= 8.479;
if(0.1 < t > 0.2)
F_PROFILE (f,thread,position)= 1.357;
if(0.2 < t <0.3)
F_PROFILE (f,thread,position)= 8.479;
if(0.3 < t > 0.4)
if(0.4 < t < 0.5)
if(0.5 < t < 0.6)
if(t > 0.6)
F_PROFILE (f, thread, position)= 0;
amr mobarez is offline   Reply With Quote
Old   April 2, 2014, 16:57
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
I think you should have a loop !!
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   April 3, 2014, 18:14
amr mobarez
you are right diamond x i tried the loop and it corrected the direction , still have problems with values but thanks for helping
Old   April 4, 2014, 06:03
upeksa is on a distinguished road
You have ambiguous instructions, for example t>0.4 is defined twice:
in (0.3 < t >0.4) and (0.4 < t < 0.5).
And t=0.1, t=0.2... is not defined.
Check that, is an error you made several times.
User diamondx is right, you need a loop.
Cheers
upeksa is offline   Reply With Quote
Old   April 4, 2014, 17:01
amr mobarez
i fixed it and it worked and here is the right code in case someone needed it
#include "udf.h"
DEFINE_PROFILE(unsteady_x_velocity12, thread, position)
face_t f;
real tm = CURRENT_TIME;
begin_f_loop (f,thread)
if(tm < 0.1)
if(tm > 0.1)
F_PROFILE (f,thread,position)= 1.36;
if(tm > 0.2)
if(tm > 0.3)
if(tm > 0.4)
if(tm > 0.5)
end_f_loop (f,thread)
Modified k-e turbulence model UDF Travis Fluent UDF and Scheme Programming 7 November 11, 2018 20:21
decomposePar pointfield flying OpenFOAM Running, Solving & CFD 28 December 30, 2013 15:05
UDF error - FLUENT received fatal signal (ACCESS_VIOLATION) Eliasjal Fluent UDF and Scheme Programming 1 March 7, 2012 11:11
problem to make a UDF parallel pilou Fluent UDF and Scheme Programming 0 March 9, 2011 06:35
Problem to parallelize a UDF pilou FLUENT 0 March 9, 2011 06:32
