FLUENT received fatal signal (ACCESS_VIOLATION)
Old   December 22, 2011, 08:55
Default FLUENT received fatal signal (ACCESS_VIOLATION)
rose
rubis is on a distinguished road
Hi all,
I wrote a UDF for calculating surface tension and concentration. UDF is interpreted sucessfully, but after running for1 one iteration it is giving Access_violation error.
best regards
rubis is offline   Reply With Quote
Old   December 29, 2011, 18:51
Real Name :)
ComputerGuy is on a distinguished road
Rubis,
Where are you defining the *tp pointer? I don't see anywhere in your code where you're defining it or passing it to the functions. If Rho and Yi are defined based upon it, and it's a null pointer, Fluent will quit with an access violation.
Let me know if I'm missing something!
Regards,
ComputerGuy
Originally Posted by rubis View Post
Hi all,
I wrote a UDF for calculating surface tension and concentration. UDF is interpreted sucessfully, but after running for1 one iteration it is giving Access_violation error. Here is my UDF:
#include "udf.h"
/* udf concentration. */
DEFINE_PROPERTY(concentration,cell,ti)
double concentration;
Thread *tp; /*thread from phase identified by phase_2_ID*/
real yi; /*mass fraction*/
real rho; /*mass volumique*/
rho = C_R(cell,tp); /*concentration is yi*rho (kg/m^3) */
yi = C_YI(cell,tp,0);
concentration=C_UDMI(cell,tp,0) = yi*rho*1000/456;
return concentration;
/* udf tension superficielle */
DEFINE_PROPERTY(surf_tension, cell, thread)
double st;
double log (double concentration);
Thread *tp;
st = 0.0728;
if (concentration < 0.094)
st = C_UDMI(cell,tp,1) = 68.49-log(concentration)*(6.516-3.353*log(concentration)) ;
else
st = C_UDMI(cell,tp,2) = -0.25*concentration+39;
return st;
best regards
ComputerGuy is offline   Reply With Quote
Old   December 31, 2011, 08:35
rose
hi,
thank you for your reply. can you give me more details.please
it's a big priblem for me
best regards
Old   January 2, 2012, 05:26
duri
duri is on a distinguished road
Hi all,
ti is a thread pointer so use ti directly instead of tp. e.g., C_R(cell,ti). Or assign tp=ti and continue to use tp.
duri is offline   Reply With Quote
Old   January 2, 2012, 20:26
Real Name :)
Duri,
I agree this change would "fix" the problem with accessing a non-null thread pointer, but it looks like rubis is performing the calculation in a multiphase environment, and that *tp should be pointing to the second (or third?) phase cell thread (note the comment: *thread from phase identified by phase_2_ID*/). It also looks like there's a species mass fraction involved (C_YI)...
Before we lead Rubis astray with things that will fix the error but not the problem, perhaps we should understand *what* Rubis is trying to calculate.
Rubis: Please write down in words, not fluent UDF code, what you're trying to calculate, and what type of system it is. For example:
I have a two-species, two-phase mixture. The calculation for surface tension is:
Mass Fraction of Species 1 * Mixture Density of the Cell * 1000/456.
Please write this as thoroughly as you can, and I'll be able to take what you write and turn it into Fluent code.
ComputerGuy
Old   February 5, 2013, 01:15
Default hello computer guy
rajatca is on a distinguished road
can you see why i get error "Fluent received fatal signal (access voilation). I am trying to run a dynamic mesh..of a body immersed in water.
rajatca is offline   Reply With Quote
Old   April 22, 2014, 15:42
Question Initialize Error
mehdis
mehdis is on a distinguished road
hi all
when i initialize the below error occurs
1. Note exact events leading to error.
2. Save case/data under new name.
3. Exit program and restart to continue.
4. Report error to your distributor.
Error Object: #f
mehdis is offline   Reply With Quote
Free Surface Ship Flow timfranke OpenFOAM Running, Solving & CFD 322 March 3, 2021 09:04
FLUENT received fatal signal (ACCESS_VIOLATION) CHAKER FLUENT 4 December 11, 2015 03:20
Problems in lauching FLUENT Lourival FLUENT 3 January 16, 2008 16:48
fatal signal (ACCESS_VIOLATION) manu FLUENT 0 December 10, 2007 06:10
FLUENT received fatal signal (ACCESS_VIOLATION) samy FLUENT 0 November 10, 2007 13:09
