Running out of UDMI, what can in use to replace it ?
Old   May 23, 2014, 13:16
Default Running out of UDMI, what can in use to replace it ?
Francisco Bailly
Sdvk is on a distinguished road
Hi Guys,
I would like to know what I can use to replace UDMI(c,t,i) in one of my case.
To quickly set the context let’s say that i have written a UDF which contains several subfunctions (1 Define_SOURCE, 1 executed at end, etc..). I use UDMI to store source terms computed in every cell of one of my thread (THREAD A) at every iterations, then I’m able to use these values in another thread (THREAD B).. (via an execute at end function , i used the values store in UDMI to modify temperature of the cell in thread B before the next iteration.. UDMI are the perfect tool to do what I need.. very simple to use as it is alreay include in software.
Problem is that I recently widen my geometry, repeating the same threads in a much bigger number.. So the mechanism of the UDF is exactly the same but I m running out of UDMI…(500 is the limit as you may know)
What can I use to replace it ? I guess I need a global variable in order to be able to use a same variable in several subfonctions of the UDF.. and I need it to be able to store a value for every cell of a thread.
Is an array can be declared as global variable to do the exact same thing of the UDMI ? Or is there anything else that I wouldn’t know ? What would you use ?
Thanks for any advice
SD
Sdvk is offline   Reply With Quote
Problem About Running Fluent In Linux mitra FLUENT 18 June 20, 2019 02:11
parallel running openFoam-1.5-dev lulo OpenFOAM 3 October 3, 2011 11:42
GUI crash and simulation engine still running RPJones FLOW-3D 2 November 9, 2010 08:18
Running Multiple Simulations from Workbench 12.1 Josh CFX 3 August 10, 2010 19:51
Running 2 CFD jobs on one PC steve podleski Main CFD Forum 17 February 16, 2000 14:40
