Parallelize discrete phase model UDF
Old   June 4, 2014, 14:06
Question Parallelize discrete phase model UDF
volume808 is on a distinguished road
Hi there
I'm doing a spray simulation using ANSYS Fluent 12.1.4 on Windows 7 and a UDF to handle some material properties and droplet evaporation. The code works as it should and simulations converge good.
The simulation runs on a multi core pc but the DPM iterations use only one core. This slows down the whole process tremendously and I wonder if it was possible to use all (8) cores for the DPM/UDF iteration aswell.
I read some threads:
http://www.cfd-online.com/Forums/flu...computing.html
http://www.cfd-online.com/Forums/flu...nt-pc-udf.html
and also the according User Guide chapters:
http://aerojet.engr.ucdavis.edu/flue....htm#DPMDEFINE
http://aerojet.engr.ucdavis.edu/flue...df/node204.htm
http://aerojet.engr.ucdavis.edu/flue...df/node207.htm
http://www.arc.vt.edu/ansys_help/flu...elize_dpm.html
Unfortunately, I wasn't able to figure out whether the UDF or the DPM itself allows only one core at a time.
Thanks for your help!
volume808 is offline   Reply With Quote
Old   June 6, 2014, 11:59
Default Update: UDF not the problem
Hi there
It turns out the UDF has no influence on my problem. Even when removing the code, DPM iterations only run on a single core.
I don't understand how to properly set up parallel DPM options. First I used "message passing", with the above stated result. When changing to "shared memory", I wanted to select 4 threads for the workpile algorithm but after running an iteration, fluent automatically resets this value to 1 (I'm running fluent parallel on 4 cores!).
Has anyone had similar issues?
Thanks again,
volume808
Discrete phase or two phase model in Fluent? andrea panizza FLUENT 14 September 6, 2015 16:18
discrete phase model venu FLUENT 4 December 28, 2011 06:52
Discrete phase model cfdkhashayar FLUENT 4 November 1, 2011 01:29
Help for INJECTION OR DISCRETE PHASE MODEL MANOJKUMAR FLUENT 0 December 27, 2005 04:05
Discrete Phase Model Ritesh Chhabra FLUENT 1 September 24, 2004 02:41
