C_CENTROID is not returning the cell center coordinates
Old   July 14, 2014, 08:52
Default C_CENTROID is not returning the cell center coordinates
jyothsna k
jyothsna k is on a distinguished road
My code is as below:
DEFINE_SOURCE(x_src,c,t,dS,eqn)
real source;
real x,y,z,r,h;
real xc[ND_ND];
C_CENTROID(xc,c,t);
x = xc[0];y=xc[1];z=xc[2];
r=sqrt(x*x+y*y); h=y/r;
t1=mu0*J;
if (z>=zl && z<=zu && r>=ri && r<=ro)
{source = -t1*h ;}
else
{source=0;}
C_UDMI(c,t,8) =x;
return source;
mu0, J, ri,ro have been defined as constants.
When i check the memory numbered 8 there are no values of x there. I have tried to incorporate a similar code in ADJUST. even there i'm facing the same problem. I have used this code before for another model with no problems. I'm unable to find the cause.
Thanks in advance
jyothsna k is offline   Reply With Quote
Old   July 14, 2014, 16:49
pakk will become famous soon enough
Sorry if this is a silly question, but did you remember to attach the udf? Are you sure that it is actually run by Fluent?
pakk is offline   Reply With Quote
Old   July 14, 2014, 22:53
jyothsna k
Thank you for your response. I have attached all my UDFs and i have been using only fluent.
cell center, c_centroid, not accessible
[General] extract the cell center coordinates if the CELLID is know openfoammaofnepo ParaView 2 January 12, 2017 06:54
?? How to get cell center coordinates? erica FLUENT 0 May 11, 2005 22:02
interpolation from cell center to vertices Zhang Main CFD Forum 3 August 22, 2003 07:31
calculate cell volume, center...? Paul Main CFD Forum 5 June 21, 2003 12:55
About Cell Center Harry FLUENT 0 December 3, 2000 04:33
