DEFINE_DPM_BC simple reflect at wall
Like Tree3Likes
  • 1 Post By pakk
  • 1 Post By pakk
  • 1 Post By pakk
Old   October 23, 2014, 16:31
Default DEFINE_DPM_BC simple reflect at wall
junz
junz is on a distinguished road
I just can't understand several code lines when studying the example in udf manual.
1. why need special treatment for 2d axisymmetric and swirl flows
and the code has if (R>1.e-20) {idim=3; normal[0]=f_normal[0];...}
why is 1.e-20?and why dimension changed to 3?
2. if (p->type==DPM_TYPE_INERT) what is the symbol ->?
I am new to udf and forget some C programming. Any help is greatly appreciated.
Thanks
junz is offline   Reply With Quote
Old   October 27, 2014, 11:38
pakk will become famous soon enough
1. If you are calculating 2d axisymmetric and swirl flows, your geometry is 2-dimensional (so variable "dim" is 2), but the velocity vector is 3-dimensional (so "idim" is defined as 3).
In the calculation of normal, you divide by the radius R. But if the radius is zero, this will give an error, because you can not divide by zero. If the radius is too close to zero, the result can be too big to store for the program. So to avoid these problems, the calculation of the normal is not done if you are close to the origin. 1e-20 is an arbitrary small value, it could also have been 1e-19 or 1e-21, I think.
2. About the symbol ->: "p->a" is short for "(*p).a". See this wikipedia page for more info.
junz likes this.
pakk is offline   Reply With Quote
Old   October 30, 2014, 10:02
junz
Thanks a lot. If I want to extract particle impact angle and velocity. How should I realize this?
Old   October 30, 2014, 10:37
DEFINE_DPM_BC(example,p,t,f,f_normal,dim)
 // P_VEL(p) is the velocity vector of the particle
 // f_normal is the normal vector of the cell face that your particle hits
 //   (not of unit length, be careful)
So you need to do some basic trigonometry to get the angle.
junz likes this.
Old   October 30, 2014, 23:24
junz
Oh, I got it. Thanks. One more question...is there any difference between use of position vector and use of velocity vector to get the impact angle? which is preferred?
Old   October 31, 2014, 03:12
I don't see how you can use the position vector (you mean the particle position vector?) to get the impact angle. So I would use the particle velocity vector and the face normal vector. You'll need both of them.
junz likes this.
Old   November 8, 2014, 14:03
junz
Hello, I have another problem now. How can I export the particle position data to an excel? And how can I get to know the number of impacts of particles?
For both situations, do I need to write a udf? Thanks very much
udf dpm reflection
Divergence in AMG solver! marina FLUENT 20 August 1, 2020 11:30
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 00:04
Enhanced Wall Treatment paduchev FLUENT 24 January 8, 2018 11:55
Stationary Water-jet wall impingement Triccio CFX 2 July 9, 2014 19:43
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 01:16
