September 9, 2014, 09:07 |
DPM, access particle data - number of tries
Hello everyone
I am able to access all particles in a domain if the number of tries is 1, but if I set this number to a higher values the number of Tracked_particle's increases (given a uniform distribution e.g.). Is it possible to also receive the data from these additional particles? Using the standard loops (over the injections or begin_particle_cell_loop), I am still only able to access the ''original'' particles. If i try to access it by using the *next pointer in the Particle struct it doesn't work. There is no *next pointer in the Tracked_particle struct. Is there any way to access the Tracked_particle data? |
July 31, 2018, 02:40 |
hxw
Rep Power: 10 |
now,I are faced with the same problem. Did you solve it? If yes, please share your works. Thanks a lot!
decomposePar no field transfert | Jeanp | OpenFOAM Pre-Processing | 3 | June 18, 2022 12:01 |
AMI speed performance | danny123 | OpenFOAM | 21 | October 24, 2020 04:13 |
foam-extend_3.1 decompose and pyfoam warning | shipman | OpenFOAM | 3 | July 24, 2014 08:14 |
Dpm model, setting particle number | wagnerqb | FLUENT | 7 | March 23, 2013 21:06 |
How to put melting Point data of inert particle in DPM model | subhankar_bhandari | Main CFD Forum | 0 | July 26, 2010 07:28 |
