Time dependent angular velocity calculation UDF
Old   June 22, 2014, 23:25
Default Time dependent angular velocity calculation UDF
shashank mishra
shashankmechguy is on a distinguished road
Hi ,
I have written this udf for evaluating time dependent angular velocity of a turbine by calculating torque at each time step and then using torque value to calculate omega.
#include"udf.h"
real w_prev= 0.0;
DEFINE_CG_MOTION(turbine, dt,vel,omega,time,dtime)
Thread *t;
face_t f;
real NV_VEC(A);
real force,torque,x[ND_ND], dw;
NV_S(vel,=,0);
NV_S(omega,=,0);
if (!Data_valid_P())
return;
/* Get the thread pointer for which this motion is defined */
t= DT_THREAD(dt);
/* Compute pressure force of body by looping through all faces */
force = 0;
torque= 0;
begin_f_loop(f,t)
F_AREA(A,f,t);
F_CENTROID(x,f,t)
torque+= x[1] * (F_P(f,t)* F_AREA(A,f,t);
end_f_loop(f,t)
/* Compute change in angular velocity */
dw= dtime* torque/ 50.00;
w_prev= w_prev + dw;
Message ("time = %f , z_omega= %f,torque = %f\n", time, w_prev, torque);
/* Set Z Component of Angular velocity */
omega[2]= w_prev;
When I am compiling this udf, I am getting this error
CMD.EXE was started with the above path as the current directory.
UNC paths are not supported. Defaulting to Windows directory.
Can anyone please help me
shashankmechguy is offline   Reply With Quote
Old   July 26, 2018, 02:23
mamly
mamly is on a distinguished road
Hello
Did you solve your problem?
I want to do the same
mamly is offline   Reply With Quote
Axisymmetric swirl - angular velocity for UDF NTSbike Fluent UDF and Scheme Programming 13 July 12, 2022 02:08
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 14 August 26, 2013 07:47
Problem with FloatingObject Leech OpenFOAM Running, Solving & CFD 10 March 29, 2012 15:24
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
