Discontinuity in UDF (How does FLUENT handle it?)
Old   January 12, 2015, 12:08
Default Discontinuity in UDF (How does FLUENT handle it?)
Adnan
adnanakhtar is on a distinguished road
I am using a UDF which involves the variation of thermal conductivity with temperature. The UDF file is as follows:
DEFINE_PROPERTY(cell_thermal_conductivity, cell, thread)
real keff;
real temp = C_T(cell, thread);
if (temp < 1373)
keff=0.9;
else
keff = 3.19;
return keff;
I wanted to find out if close to the temperature 1373, FLUENT tries to make the function continuous?
I have a slight difference in results when I calculate using a code by considering it as a discontinuity and when I calculate using FLUENT.
Please any help in this regard would be deeply appreciated.
adnanakhtar is offline   Reply With Quote
Old   January 13, 2015, 04:00
upeksa is on a distinguished road
Fluent does not do any magic tricks, it will do whatever you program.
You may probably see an oscillation on your results at 1373 K.
upeksa is offline   Reply With Quote
discontinuity, udf code
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
fluent udf problem: write specific data for every iteration in a file. nnvoro Fluent UDF and Scheme Programming 1 May 27, 2013 15:26
UDF for Viscoelastic Fow in Fluent skris2009 FLUENT 2 September 19, 2011 23:59
fluent UDF external library lapack problem Rick FLUENT 0 May 7, 2008 10:16
UDF problem caused by various version of Fluent Yurong FLUENT 3 January 15, 2006 10:57
