September 1, 2017, 13:13 |
access the adjacent cells of a node
mach_25
Hi
Does anybody know how I can access the adjacent cells of a node in udf ? is there any macro or instruction for this purpose? my project contains dynamic mesh. i wanna investigate the effects of erosive burning in solid fuel rocket. for this purpose i need (du/dy) near the burning area.(u is the velocity of flow in the direction of x). and (du/dy) determines the burning rate amount(r) according to errosive burning. then burning rate(r) determines how nodes of fuel boundary retreats(x=r * t). t is time step. type of moving boundary(fuel boundary) is user-defined. and my project is 2-D. as you know i should work with nodes in moving boundary(fuel boundary) in dynamic mesh and according to my description i wanna access the adjacent cells of moving boundary(fuel boundary) nodes. thanks for any help this is the picture of this project. an hypothetical 2-D solid fuel rocket: |
adjacent cell of node, dynamic mesh, node, udf, user-defined bc |
[ICEM] Error in mesh writing | helios | ANSYS Meshing & Geometry | 21 | August 19, 2021 14:18 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
Fast Search adjacent cells in an unstructured grid | andreyh | Mesh Generation & Pre-Processing | 0 | November 1, 2015 17:40 |
[blockMesh] Adjacent cells are disjunct after blockMesh run | NablaDyn | OpenFOAM Meshing & Mesh Conversion | 1 | October 28, 2015 07:15 |
[ICEM] error analysis | despaired student | ANSYS Meshing & Geometry | 7 | June 27, 2012 11:57 |
