Udf stopped my runs !!
Like Tree2Likes
  • 1 Post By souria
  • 1 Post By Saidul
Old   January 15, 2015, 13:31
Default Udf stopped my runs !!
souria
souria is on a distinguished road
Hey everyone,
I'm simulating sediment transport using DPM. So, I tried an UDF to follow the particules. I built and hooked the udf, no problem. But, when I try to track the particules (means when I run the DPM) I got this message :
" DPM Iteration ....
MPI Application rank 0 exited before MPI_Finalize() with status -1
The fl process could not be started. "
Please, does anyone know where it comes from ?? !!
Thanks for your help
Souria
shahab2710 likes this.
souria is offline   Reply With Quote
Old   January 15, 2015, 16:20
Harry321 is on a distinguished road
Could you show your UDF?
Harry321 is offline   Reply With Quote
Old   January 15, 2015, 16:58
souria
Here is the UDF :
/* UDF for computing cell co-ordinates */
#include "udf.h"
#include "sg.h"
#include "prop.h"
#include "dpm.h"
#include "surf.h"
#define WALL_ID 5
DEFINE_DPM_SCALAR_UPDATE(particle_coords, c, ct, initialize, p)
real A[ND_ND];
int n;
face_t f;
Thread *ft;
c_face_loop(c, ct, n)
f=C_FACE(c, ct,n);
ft=C_FACE_THREAD(c, ct, n);
if (NNULLP(ft))
if (THREAD_ID(ft)== WALL_ID)
p->user[0] = p->state.pos[0];
p->user[1] = p->state.pos[1];
p->user[2] = p->state.pos[2];
DEFINE_DPM_OUTPUT(Particle_coords_output, header, fp, p, thread, plane)
char name[10];
if (header)
if (NNULLP(thread))
par_fprintf(fp,"(%s %d)\n", THREAD_HEAD(thread)-> dpm_summary.sort_file_name,5);
else
par_fprintf(fp,"(%s %d)\n", plane->sort_file_name,5);
par_fprintf(fp,"(%10s %10s %10s)\n","X", "Y", "Z");
else
sprintf(name,"%s:%d", p->injection->name,p->part_id);
sprintf(fp,"(%10.6g %10.6g %10.6g)\n", p->user[0], p->user[1], p->user[2]);
thanks for your help
Old   January 15, 2015, 17:00
I don't know:/
Old   January 15, 2015, 17:10
souria
I don't know:/
thanks anyway
Old   January 16, 2015, 04:02
pakk will become famous soon enough
I have my doubts with
I think you'd rather use:
par_fprintf(fp,"(%10.6g %10.6g %10.6g)\n", p->user[0], p->user[1], p->user[2]);
For the rest, it might be that you have to add some compiler directives (#if !RP_HOST) to the DEFINE_DPM_OUTPUT macro, because the host does not know about some variables.
pakk is offline   Reply With Quote
Old   January 16, 2015, 04:21
souria
Hi Pakk,
I change it but it gives the same error ! Excuse me, but what didi you mean by (#if !RP_HOST). PS. I'm not an expert in UDF, I just begun ...
Old   January 16, 2015, 06:28
The Fluent help has a "UDF manual", chapter 7.5.1 explains the compiler directives that I referred to.
Old   January 18, 2015, 20:12
souria
Thank you, I will check this...
Old   January 20, 2015, 21:10
S. Morichika
Saidul is on a distinguished road
I compiled the the same UDF with two warnings first time (Image attached) and no warning when I compiled it for second time. Then run the simulations without any error but can't find the output file . The fluent console shows that some particles are trapped.
Can anyone help regarding this problem.
Thanks in advance.
Saidul
Saidul is offline   Reply With Quote
Old   January 21, 2015, 11:08
Did you select "write to file" in the appropriate place, and remember which name you gave the file?
Old   January 21, 2015, 18:49
S. Morichika
Yes, I did everything with no results. I think the problem is with code. We have to check the print command. When I changed the print command
char name[100];
if (header)
if (NNULLP(thread))
cxprintf(fp,"(%s %d)\n", THREAD_HEAD(thread)-> dpm_summary.sort_file_name,8);
else
cxprintf(fp,"(%s %d)\n", plane->sort_file_name,8);
cxprintf(fp,"(%10s %10s %10s)\n","X", "Y", "Z");
else
cxprintf(fp,"(%10.6g %10.6g %10.6g)\n", p->user[0], p->user[1], p->user[2]);
and run the simulation, it showed a fatal error as " Error: received a fatal signal (Segmentation fault)" and stopped the simulation.
I don't know what is happening ....
saeed
Old   January 21, 2015, 20:44
John Yu
fishball is on a distinguished road
From the error message, it seems the paraellel Fluent process could not be strated. Have you try to run in Serial Model?
Originally Posted by souria View Post
Hey everyone,
Souria
fishball is offline   Reply With Quote
Old   February 5, 2015, 11:23
souria
I fixed the problem.
It comes from parallel, so I parallelized the UDF. I just added :
#if !RP_NODE /*in the begining of the UDF*/
#endif /*in the end of the UDF*/
Hope it could help others...
Souria
Old   February 9, 2015, 01:37
John Yu
Souria
Cool, Thanks
Old   February 12, 2015, 01:44
S. Morichika
I compile the following UDF with a warning.
# Generating udf_names.c because of makefile dpm_modification.obj
udf_names.c
udf_names.c(9) : warning C4113: 'void (*)()' differs in parameter lists from 'void (*)(void)'
udf_names.c(10) : warning C4113: 'void (*)()' differs in parameter lists from 'void (*)(void)'
# Linking libudf.dll because of user_nt.udf udf_names.obj dpm_modification.obj
Microsoft (R) Incremental Linker Version 10.00.30319.01
Copyright (C) Microsoft Corporation. All rights reserved.
How can I fix it.....
#include "udf.h"
#include "sg.h"
#include "prop.h"
#include "dpm.h"
#include "surf.h"
#define WALL_ID 8 (line 9)
real A[ND_ND];
int n;
face_t f;
Thread *ft;
if (THREAD_ID(ft)==WALL_ID)
char name[1000];
if (header)
if (NNULLP(thread))
par_fprintf_head(fp,"(%s %d)\n", THREAD_HEAD(thread)->dpm_summary.sort_file_name,3);
else
par_fprintf_head(fp,"(%s %d)\n", plane->sort_file_name,3);
par_fprintf_head(fp,"\n %10s %10s %10s","X", "Y", "Z");
else
par_fprintf(fp,"%10.6g %10.6g %10.6g\n", p->user[0], p->user[1], p->user[2]);
ramakant likes this.
Old   February 12, 2015, 04:28
Look more carefully: the warning that Fluent is giving, points to the file "udf_names.c", not to your file.
It is a file that Fluent makes while (preparing to) compile your code.
I get these warnings all the time, since migrating to Fluent 15.0. It is not a mistake in your code, but a mistake in Fluent code. You can ignore it since it does no harm; if you want to get rid of the code then contact the Fluent developers.
Old   February 12, 2015, 21:31
S. Morichika
Yes, thanks a lot. I got the point.
UDF using c_face_loop(c,t,i) frederic FLUENT 3 January 16, 2017 23:17
Parallelize UDF? Which kind of UDF? Lilly FLUENT 5 March 25, 2014 02:05
Help! Delete the UDM codes in the UDF Messi Fluent UDF and Scheme Programming 2 January 28, 2014 09:01
udf for multiple reaction alihosseini63 Fluent UDF and Scheme Programming 0 July 4, 2013 18:37
UDF programming fullmonty FLUENT 5 June 30, 2011 02:40
