Udf to define new mixing law between properties of different phases in Mixture model |
February 24, 2015, 03:23 |
saurabh gupta
Rep Power: 11 |
As far as i know that Mixture model uses mixture rule to formulate a property of mixture from different phase properties but if i have to define any different relationship among phase material properties then which Macro (DEFINE PROPERTY ??) should i use to write UDF and where it will be hooked up ...i mean in individual phase properties or somewhere else in FLUENT.
In my case mixture viscosity is a function of two primary and secondary phase viscosity but this function is not mixing law.Any help? |
UDF for defining granular viscosity in mixture model | priyanka.asp | Fluent UDF and Scheme Programming | 7 | May 19, 2019 18:16 |
mixture model or multiphase model in my UDF? | aleisia | Fluent UDF and Scheme Programming | 0 | June 8, 2011 13:25 |
A question about UDF utility in mixture and multiphase model | aleisia | Fluent UDF and Scheme Programming | 0 | June 7, 2011 16:32 |
UDF FOR UNSTEADY TIME STEP | mayur | FLUENT | 3 | August 9, 2006 10:19 |
