negative cell volume error in fluent
Old   February 21, 2015, 15:44
Default negative cell volume error in fluent
Alex 0122 is on a distinguished road
Hello everyone,
I'm new to dynamic calculation in CFD and for a school project I need to simulate the flow around a Savonius wind turbine using Fluent. In order to do so, I initialise the simulation with a steady flow and then use a UDF function in a transient flow but then, when I launch the simulation I get this error message 'Update-Dynamic-Mesh Failed. Negative cell volume detected'. I already tried to reduce the time step size and checked the mesh and the UDF file for any flaws but nothing. Does anyone have an idea to solve this issue ?
Many thanks.
Alex 0122 is offline   Reply With Quote
Old   February 23, 2015, 01:41
maverick123 is on a distinguished road
First do mesh/check .
It should detect negative volume cell. Then try to fix that problem with
/mesh/repair-improve repair or try many other options from repair menu.
If problem still exists, then you have to improve mesh in mesher only.
Regards
Originally Posted by Alex 0122 View Post
Hello everyone,
Many thanks.
maverick123 is offline   Reply With Quote
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
Pointwise-FLUENT: Negative Cell Volume dvzd72 Pointwise & Gridgen 15 May 14, 2020 06:51
negative cell volume & sync point error dynamicmesh FLUENT 0 June 17, 2012 15:34
negative cell volume during dynamic meshing Tamjid FLUENT 1 September 5, 2011 02:33
Warning 097- AB Siemens 6 November 15, 2004 04:41
