rp-var-define problem
Old   August 13, 2012, 00:46
Default rp-var-define problem
Syavash Asgari
syavash is on a distinguished road
Hi Guys,
I have written a UDF as below: no problem in compiling but when i run Fluent, there is an error message,
DEFINE_EXECUTE_AT_END(heat_flux)
Domain *d;
Thread *t;
face_t f;
real A[ND_ND];
real q;
real T_W;
real htc;
real q_t;
real TT = RP_Get_Real("T-ref");
d = Get_Domain(1);
t = Lookup_Thread(d,3);
begin_f_loop (f,t)
F_AREA(A,f,t);
q = WALL_HEAT_FLUX(f,t); /* gets the TOTAL Heat flux vector at the surface */
q_t = q / NV_MAG(A);
T_W = F_T(f,t);
htc = ABS(q_t / (T_W - TT));
C_UDMI(F_C0(f,t),THREAD_T0(t),0) = q_t;
C_UDMI(F_C0(f,t),THREAD_T0(t),1) = htc;
end_f_loop (f,t)
The following error message appears:
Error: rpgetvar: T-ref: undefined variable
Error Object: ()
I have already defined T-ref using
(if (not (rp-var-object ‘T-ref))(rp-var-define ‘T-ref 290 ‘real #f)) in TUI so I think there should be no problems!
I will appreciate if you can help me resolve this problem,
tnx
syavash is offline   Reply With Quote
Old   August 13, 2012, 02:32
gearboy is on a distinguished road
That means the scheme variable "T-ref" has not been defined.
I believe the sentence RP_Get_Real("T-ref") is to get the reference temperature, commonly, 298.15K. If the scheme variable is not defined in your system, you can also use
real TT = T_REF;
to get the reference temperature.
Originally Posted by syavash View Post
Hi Guys,
Domain *d;
Thread *t;
face_t f;
real A[ND_ND];
real q;
real T_W;
real htc;
real q_t;
d = Get_Domain(1);
begin_f_loop (f,t)
F_AREA(A,f,t);
T_W = F_T(f,t);
end_f_loop (f,t)
Error Object: ()
tnx
gearboy is offline   Reply With Quote
Old   August 13, 2012, 14:30
Syavash Asgari
real TT = T_REF;
Tnx for you reply.
Actually I don't understand you point "if the scheme variable is not defined in yor system".
As you mentioned there is no problem when i write TT=T-ref. But i need to change this value frequently and that's why i have to use rp- var-define.
Is there any solution?
Old   March 15, 2015, 07:20
yuemeng
yuemeng is on a distinguished road
Tnx for you reply.
hi,i has the same problem, can you how you deal with the problem, thanks.
yuemeng is offline   Reply With Quote
Old   March 15, 2015, 15:14
`e`
`e` is on a distinguished road
Have you tried gearboy's recommendation above? Otherwise, you could hard code the reference temperature into your script, T_reference = 298.15; or similar.
`e` is offline   Reply With Quote
Old   March 16, 2015, 09:20
pakk will become famous soon enough
Worth a try: avoid capital letters in scheme.
So not "T-ref", but "t-ref".
pakk is offline   Reply With Quote
problem to define a baffle mojtaba Siemens 2 January 21, 2008 11:19
ReleaseNotes13 website link problem maka OpenFOAM 2 November 22, 2006 04:32
some problem about "define boudary" ztdep Siemens 4 October 11, 2005 06:57
UDF problem : inlet velocity in cyl. coord. system Jongdae Kim FLUENT 0 June 15, 2004 11:21
Problem on boundry of two phase flow youngan CFX 0 June 30, 2003 02:32
