span-wise averaging
Old   June 4, 2015, 17:43
Default span-wise averaging
Syavash Asgari
syavash is on a distinguished road
Hello mates,
I have developed a UDF which is able to perform span-wise averaging in the homogenous direction. It can be handy in LES or DNS simulation if one would want to plot span-wise averaged streamlines. Note that this UDF only works if there is already a time-averaged solution (Data sampling checked).
Enjoy!!
DEFINE_ON_DEMAND(Span_Averaged)
Domain *d = Get_Domain(1);
Thread *t0 = Lookup_Thread(d,ID);  /* ID is of periodic BC */
Thread *t;
cell_t c;
face_t f;
double x[ND_ND],x2[ND_ND],xc[ND_ND];
double X, Y, u_mean, v_mean, w_mean, SUM_u, SUM_v, SUM_w, u_Averaged, v_Averaged, w_Averaged, TOL, temp1, temp2, temp3;
int counter = 0;
int counter2 = 0;
TOL = 2e-3;
SUM_u = 0.0;
SUM_v = 0.0;
SUM_w = 0.0;
#if !RP_HOST
  begin_f_loop(f,t0)
      F_AREA(x2,f,t0);
      F_CENTROID(x,f,t0);
      X = x[0];
      Y = x[1];
      counter2 +=1;
      Message("face %d\n", counter2);
  thread_loop_c(t,d)
        if (FLUID_THREAD_P(t))
             begin_c_loop(c,t)
                  C_CENTROID(xc,c,t);
                  if (ABS((xc[0] - X) / X) < TOL && ABS((xc[1] - Y) / Y) < TOL)
                        counter +=1;
                        u_mean = C_STORAGE_R(c,t, SV_U_MEAN)/delta_time_sampled;
                        v_mean = C_STORAGE_R(c,t, SV_V_MEAN)/delta_time_sampled;
                        w_mean = C_STORAGE_R(c,t, SV_W_MEAN)/delta_time_sampled;
                        SUM_u = SUM_u + u_mean;
                        SUM_v = SUM_v + v_mean;
                        SUM_w = SUM_w + w_mean;
              end_c_loop(c,t)
        if (counter > 0)
              u_Averaged = SUM_u / counter;
              v_Averaged = SUM_v / counter;
              w_Averaged = SUM_w / counter;
              temp1 = u_Averaged;
              temp2 = v_Averaged;
              temp3 = w_Averaged;
        else
              u_Averaged = temp1;
              v_Averaged = temp2;
              w_Averaged = temp3;
              SUM_u = 0.0;
              SUM_v = 0.0;
              SUM_w = 0.0;
              Message("counter %d\n", counter);
              counter = 0;
              begin_c_loop(c,t)
                  C_CENTROID(xc,c,t);
                     C_UDMI(c, t, 0) = u_Averaged;
                     C_UDMI(c, t, 1) = v_Averaged;
                     C_UDMI(c, t, 2) = w_Averaged;
              end_c_loop(c,t)
  end_f_loop(f,t0)
#endif
Note: The parameter "TOL" should be adjusted to make sure all the cells in the span-wise direction are taken into account!
Another point, this code only works with Hexa grids!
Regards
syavash is offline   Reply With Quote
Starting field averaging using libFunctionObject after certain time eelcovv OpenFOAM Programming & Development 25 December 7, 2015 22:28
How to do spatial averaging - LES pipe flows ? Dan1788 OpenFOAM Running, Solving & CFD 0 December 12, 2014 14:50
RANS - time averaging? Connor STAR-CCM+ 1 April 5, 2011 04:52
When to use mass flow averaging cspectre CFX 2 December 6, 2009 05:30
Averaging LES iko FLUENT 3 July 3, 2008 05:55
