UDF for periodic boundary condition
Old   May 31, 2011, 03:35
Default UDF for periodic boundary condition
Angie
Angeline is on a distinguished road
Hi Guys
My case is gas solid flow in a pipe. Instead of simulating a long pipe , I take a small length using periodic BC. After every iteration the values from outlet will be updated in inlet. I want to write a UDF for this.
Can anybody help me please.
Regards
Angie
Angeline is offline   Reply With Quote
Old   May 31, 2011, 08:07
Amir's Avatar
Amir
Amir is on a distinguished road
Hi Angie,
If you don't want to use FLUENT periodic BC (maybe for its restrictions ?), you have to loop over desired faces with an exhaustive search. (it's much more better to have same topologies in two faces)
Regards,
Amir
Amir is offline   Reply With Quote
Old   June 1, 2011, 02:02
Angie
Thanks Amir for your reply.
Can you please elaborate it more for me to understand.......
Regards
Angie
Old   June 1, 2011, 05:45
Amir's Avatar
Amir
Regards
Angie
First, ensure whether you can use periodic boundary condition of FLUENT or not; check its restrictions in user manual. If you can use that, it wouldn't need any UDF.
If it doesn't the case, for writing UDF and for simplicity, use the same topology on both faces which you want to project data. After that, you can use 2 procedures:
1) if you have used same topologies and strategies in creating faces, FLUENT searchs faces' elements in the same manner, so you can write data in a temporary files and then use them; in this method, you have to ensure same searching manner.
2) in this method you can use exhausting search between to faces to achive appropriate cells to which you want to project data. (using this method is not reasonable and also time-consuming and it isn't recommended)
Regards,
Amir
Old   April 30, 2012, 08:51
Learner
raghu.tejaswi is on a distinguished road
Hi Angeline, Amir
I assume the use of periodic BC is to reduce the computational domain. I have been using it to update the values of outlet to inlet in a 2D flow.
I am basically using it to achieve a fully developed flow (Thermally and hydrodynamically).
Amir: Could you pls clarify if I can really use periodic BC to achieve fully developed temperature profile? My results from simulations match with the analytical results but the temperature profile doesnt seem to maintain constant even after 10m length of the pipe. Is there anything I need to note before using periodic BC?
Raghu
raghu.tejaswi is offline   Reply With Quote
Old   April 30, 2012, 10:04
François Grégoire
macfly is on a distinguished road
Hi Raghu,
Thermally fully developed doesn't mean that temperature profile no longer changes. It is the relative shape of the profile that no longer changes, and the local convection coefficient becomes a constant independent of flow axis.
macfly is offline   Reply With Quote
Old   November 7, 2015, 00:08
Talking Reason for divergence of continuity in Periodic boundary condition
HK
Luttappy is on a distinguished road
Hi all
I was working on Periodic Boundary condition for a wavy channel considering one module at a time in Fluent at very low Re (Laminar and steady).
In this case except continuity both momentum and energy equations are converging.
What might be the reason for this issue
Thanks in Advance.
Luttappy is offline   Reply With Quote
Resolved: Changing boundary condition with UDF according to pressure outlet boundary alpemre Fluent UDF and Scheme Programming 12 February 24, 2014 10:18
Boundary Condition Types Using Scheme and UDF Nasir FLUENT 0 September 15, 2008 21:54
UDF for pressure oulet boundary condition Jubs FLUENT 0 February 13, 2007 00:26
UDF for the boundary condition Sridhar FLUENT 3 July 13, 2001 19:18
UDF : boundary condition ID Flav FLUENT 4 June 28, 2001 09:52
