UDF for unsteady velocity inlet
Like Tree6Likes
  • 1 Post By chem engineer
  • 2 Post By `e`
  • 2 Post By upeksa
Old   April 11, 2015, 03:16
Default UDF for unsteady velocity inlet
Lida
chem engineer is on a distinguished road
Hello everyone,
I'm new and amateur in the world of CFD and fluent and I should use a udf for a velocity inlet in a cylindrical pipe.the velocity inlet follow a step function as is described:
for (t=time) t<10 v=6.5*(1-r/3.5)^(1/7)
t>10 v=0
I don't know how to write a step function.
does anyone can help me?
Thank you in advance
Akash Siddique likes this.
chem engineer is offline   Reply With Quote
Old   April 11, 2015, 03:54
`e`
`e` is on a distinguished road
Here's a start with the structure of the code, add in your velocity profile equation and you're set.
#include "udf.h"
DEFINE_PROFILE(unsteady_velocity_profile, t, i)
    real current_time;
    face_t f;
    current_time = CURRENT_TIME;
    begin_f_loop(f, t)
        if (current_time < 10.)
            // first period of time
        else
            // second period of time
    end_f_loop(f, t)
chem engineer and tooraj like this.
`e` is offline   Reply With Quote
Old   April 12, 2015, 04:17
Lida
#include "udf.h"
    real current_time;
    face_t f;
    begin_f_loop(f, t)
        else
    end_f_loop(f, t)
thank you so much for your answer.
should I use this macro in a main steady state program? and do I need to use two loops for time and location? is the macro i have written and attached here correct?
tooraj likes this.
Old   April 12, 2015, 04:20
Lida
should I use this code in a main steady state code? and do I need to use two loops for time and location? is the code i have written correct?
#include "udf.h"
real current_time;
real x[ND_ND];
real y,u;
face_t f;
begin_f_loop(f, t)
begin_f_loop(f, thread)
F_CENTROID(x,f,thread);
y = x[1];
u=6.5*(1-y/3.5)^(1/7);
else
u=0;
end_f_loop(f, thread)
end_f_loop(f, t)
Old   April 12, 2015, 04:53
`e`
Don't use two for loops. Set your boundary value with F_PROFILE(f,t,i); setting u=.. has nothing to do with the boundary condition value. Have a read of the UDF Manual for details.
Old   April 12, 2015, 06:28
Lida
according to what I read in UDF manuals, because this pipe is 2D I should define real x[ND_ND] that stand for a 2D array: x[1]=x & x[2]=y. x is the horizontal direction of flow and y is the vertical. I understood my mistake about defining "u" and I used F_PROFILE. so is this new code correct. if it is not would you please write the correct form?
real current_time;
real x[ND_ND];
real y;
face_t f;
begin_f_loop(f, t)
F_CENTROID(x,f,t);
y = x[1];
F_PROFILE(f,t,i)=6.5*(1-y/3.5)^(1/7);
else
F_PROFILE(f,t,i)=0;
end_f_loop(f, t)
Old   April 12, 2015, 06:34
`e`
This code is looking good, have you tried compiling and running this boundary condition profile?
Old   April 12, 2015, 07:25
Lida
I tried to compile it but I faced this error:
1 file(s) copied.
The system cannot find the file specified.
(system "copy C:\Fluent.Inc\fluent6.3.26\src\makefile_nt.udf libudf\ntx86\2ddp\makefile")
1 file(s) copied.
(chdir "libudf")()
(chdir "ntx86\2ddp")()
'nmake' is not recognized as an internal or external command,
operable program or batch file.
Done.
"C:/Users/LIDA/Desktop"
Opening library "libudf"...
Error: open_udf_library: The system cannot find the file specified.
Error Object: ()
as far as I searched and found, I should use Microsoft visual Studio program to compile it.but I haven't install it yet.
Old   April 12, 2015, 08:09
`e`
Yea, you require a compiler such as Microsoft Visual Studio contains for compiling UDFs. Otherwise try interpreting this UDF (it may not require compiling).
Old   April 12, 2015, 08:55
Lida
I faced this error while interpreting it:
cpp -I"C:\Fluent.Inc\fluent6.3.26/src" -I"C:\Fluent.Inc\fluent6.3.26/cortex/src" -I"C:\Fluent.Inc\fluent6.3.26/client/src" -I"C:\Fluent.Inc\fluent6.3.26/multiport/src" -I. -DUDFCONFIG_H="<udfconfig.h>" "C:\Users\LIDA\Desktop\inlet.c"
Error: C:\Users\LIDA\Desktop\inlet.c: line 12: thread: undeclared variable
I don't know what does it mean and also if it can be solved or not.
Old   April 12, 2015, 19:25
`e`
Your error has provided the error type (undeclared variable, you should declare variables before using them) and where it has occurred (line 12 of inlet.c: your UDF?).
Old   April 13, 2015, 03:37
upeksa is on a distinguished road
the line:
is wrong.
Use:
F_PROFILE(f,t,i)=6.5*pow((1-y/3.5),(1/7)) ;
chem engineer and Oula like this.
upeksa is offline   Reply With Quote
Old   August 9, 2015, 12:52
tooraj
tooraj is on a distinguished road
hello every one
i have two formolas and i want to write them in c+
the inlet velocity in the z direction from 0 to the prabolic profile
V(r)= 4.5 ( (r+0.1mm)/0.2mm)(1-(r+0.1mm)/0.2mm)
during the 2µs. the velocity is then v(r) for 10µs and finally decreases to 0 another 2µs the time dependent velocity profile in the z direction can then be defined as:
v(r,t)=(step(t-1.〖10〗^(-6))-step(t-13.〖10〗^(-6))).v(r)
where t is given in seconds and step(t) is a smooth step function
PLEASE help me
i wrote this but fluent cant run it:
#include "udf.h"
DEFINE_PROFILE( unsteady_velocity_profile, t, i,r,t,v,a,b,total,)
real current_time;
real x[ND_ND];
real y;
face_t f;
begin_f_loop(f, t)
F_CENTROID(x,f,t);
y = x[1];
F_PROFILE(f,t,i)=4.5*pow[(y+(0.1*0.001))/(0.2*0.001)]*[1-((y+(0.1*0.001))/0.2*0.001))];
"a event folat from 0 through 200*0.001
for(i=0;i<=200*0.001;i+=0.000001)
a+=i;
cout<<"sum in step one is"<<a;
"b even float from 0 through 200*0.001
for(i=0;i<=200*0.001;i+=13*0.000001)
b+=i;
cout<<"sum in step two is"<<b;
v total=(a-b)*v;
cout<<"total is:"<<total<<end l;
tooraj is offline   Reply With Quote
UDF: Change boundary condition. Velocity inlet to pressure inlet at time "t" jpina FLUENT 10 April 11, 2015 14:19
UDF for 3D rectangular Inlet velocity Mohammed Attya Fluent UDF and Scheme Programming 0 January 28, 2015 13:18
(UDF) Sinusoidal inlet velocity in Fluent star Fluent UDF and Scheme Programming 1 December 19, 2013 16:23
Fluent UDF load and apply inlet velocity b.c. Knut Lehmann Main CFD Forum 2 June 29, 2007 04:53
Urgent! Help on UDF to set inlet velocity Ray Hong FLUENT 4 December 30, 2005 12:32
