how to express the exponential function in a UDF |
May 31, 2015, 16:29 |
Mohamed
Rep Power: 15 |
Hi all.
how to express the exponential function in a UDF on FLUENT 15.0, I used the epression exp (value) as UDF following shows: but it does not work. HTML Code:
#include "udf.h"
DEFINE_SPECIFIC_HEAT(my_user_cp, T, Tref, h, yi)
real cp;
real Tmelt=299.6;
real cps=1413;
real cpl=1797;
real lf=232000;
if (T <= Tmelt)
cp = cps+lf*exp(-0.5*(T-Tmelt)*(T-Tmelt));
else /*(T > Tmelt)no need if statement, "else" is enough*/
cp = cpl+lf*exp(-0.5*(T-Tmelt)*(T-Tmelt));
*h = cp*(T-Tref);
return cp;
THank you. |
June 1, 2015, 08:20 |
Rep Power: 26 |
"it does not work." is not very useful. To help you, more information would be better.
Does it compile? Do you get errors? Do you get warnings? Do you get results at all? What do you get for results, what do you expect? |
June 1, 2015, 11:17 |
#3 | |
Mohamed
Rep Power: 15 |
So. I compiled the UDF. No errors? no warnings? I have not achieved the desired results by that UDF For the results, it did not work for variable specific heat. |
June 1, 2015, 12:20 |
#4 | |
Rep Power: 12 |
You are not the first one to give this approach to simulate multiphase flow, check this post (also answered by me, by the way) http://www.cfd-online.com/Forums/flu...em-cp-udf.html I bet you have a similar problem as related in that post. Cp variable is quite odd in Fluent: it has its particular UDF instead a "classic" DEFINE_PROPERTY macro. That because the solver integrates Cp and get enthalpy, although it is no that trivial indeed. I think that your (only) solution is to use the multiphase models of Fluent (VOF, Euler, etc), and if you eventually need an UDF, you should use a DEFINE_SOURCE and DEFINE_MASS_TRANSFER. You will have many posts in this forum dealing with this If you want to give a last try to your approach, you could drop the energy relaxation factor. It is set as 1 as default, try 0.8 or lower. Cheers. |
June 1, 2015, 15:08 |
#5 | |
Mohamed
Rep Power: 15 |
UDF for specific heat as function of pressure | ghobold | Fluent UDF and Scheme Programming | 20 | August 22, 2019 08:19 |
using METIS functions in fortran | dokeun | Main CFD Forum | 7 | January 29, 2013 04:06 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
UDF: exporting a variable between two DEFINE function | Carlo | FLUENT | 3 | August 19, 2009 12:21 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 06:51 |
